oil pan gasket replacement ???? - JeepForum.com
post #1 of 5 Old 11-03-2005, 08:03 PM Thread Starter
rem
ok...while replacing the oil pan....and gasket....do you need to silicone anywhere on the gasket or do any other prep to it?? it is on a 2005 unlimited rubicon 4.0L thanks for the help...
rem is offline
post #2 of 5 Old 11-03-2005, 08:57 PM
Blk2kTj
When I did mine i had to use rtv to fill in the gaps on the rear left and right of the mating surface. (by the flywheel).
Also, I had a hell of a time getting the rear lip of the gasket to seat properly on the oil pan, the first 2 times the rear lip was not seated right and i tightened it down and distorted the gasket, so on my third gasket, I stuck dabs of Rtv randomly around the gasket, tightened the gasket on with the bolts (no oil pan) then after it dried removed the bolts, put the pan on carefully, then retightened. Watch that rear lip.
And if you dont dab rtv in those two rear gaps in the mating surface it will be quite apparent after you have everything together and start it up.
2000 Tj 4.0
Id assume yours should be similar with the rubber gasket.
regards.
Blk2kTj is offline
post #3 of 5 Old 11-04-2005, 11:02 AM
Fyrflie
Fyrflie's Avatar
If you buy a good gasket, you really shouldn't need any RTV at all.
When I did mine three weeks ago, I used the Permatex gasket sealer, only to hold the gasket in place until I got the pan mated to the engine. Then tightened it down and all was good.
The gasket I used was the rubber type with what appeared to be some type of stiffeners built into the long sides of the gasket to keep it straight.
2000 TJ Sahara
4.0, 5 Speed, D30, D44 w/Detroit Truetrac, 4.56 gears
Rancho Lift, Body Lift, Motor Mount Lift, SYE & 33" tires
Fyrflie is offline
post #4 of 5 Old 11-04-2005, 04:07 PM
Blk2kTj
I think i had a fel pro gasket when i did mine. Same thing, both the left and right sides were stiffened, but the front and rear parts are verry rubbrerish.
I had to use RTV in the rear corners, and I think the instruction to do so came with the gasket.
Just check to make sure the gasket dosent specifically call for rtv and you should be fine. if it wants you to seal soemthing with it there would probably be a note with the gasket saying "IMPORTANT: Use rtv at so and so."
Either way its a pretty basic job. but it looks like it might be best to stick the gasket to either the pan or the engine beforehand to keep it aligned.
Blk2kTj is offline
post #5 of 5 Old 11-05-2005, 08:23 AM
davenjeip
davenjeip's Avatar
IIRC, there are four spots where the factory used a dab of silicone.
I tried to replicate that when I installed mine.
2003 TJ
www.davenjeip.com
davenjeip is offline
oil pan gasket replacement scottieboy YJ Wrangler Technical Forum 5 06-15-2008 11:59 AM
head gasket replacement ErnieG TJ Wrangler Technical Forum 2 01-27-2008 06:45 AM
4.0L Head Gasket Replacement NamesMUD YJ Wrangler Technical Forum 7 09-24-2007 04:33 AM
Head Gasket Replacement? Jarvo2 TJ Wrangler Technical Forum 4 01-08-2007 10:18 PM
Head gasket replacement ckracing TJ Wrangler Technical Forum 3 12-11-2006 09:26 PM
