Quantcast Oil level and suspension questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Oil level and suspension questions
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 07-28-2008, 10:27 PM   #1
shadows_lair
Hi all,
Two questions:
First, my oil dipstick reads past full by 1/4 inch when I put 6 quarts in my 4.0l engine. (06 Unlimited Rubicon) My other car reads a half-quart low with the specified capacity fill. Is the stick off, or the capacity off? Should I re-mark the dipstick, or plan on putting in less oil? This is with a new stock filter, and after I've run the car for a while, shut it off and taken the measurement while the engine is warm.
Next question: There is a sway bar at the rear of my jeep with two arms that retain it in position. It is also tied to the rear axle at two points about a foot from the arms mentioned above. The bolts that hold the sway bar in place are tight, but there is a bit of lateral end play in the arms at the point where the sway bar is mounted to the arms. Is this normal?
Thanks in advance.
Mike H. in Sedona, Az
shadows_lair is offline   Reply With Quote
Old 07-28-2008, 10:56 PM   #2
EagleStorm
2008 WK
the book says 6 qt thats what i put in them no matter what the stick says
should not be any play in those parts
EagleStorm is offline   Reply With Quote
Old 07-29-2008, 07:34 AM   #3
Elwood
Conservative Jeeper
Elwood's Avatar
Mine reads a bit over full after putting in 6 quarts as well. I wouldn't worry about it.
2006 LJ Rubicon, Auto. Currie 4" short arm with 3" AEV springs, Rancho 9000xl, Currie adj. front and rear track bars, Antirock sway bar, 305/70/16 Dick Cepek F-C II's, Warn 9500.
Elwood is offline   Reply With Quote
Old 07-29-2008, 07:42 AM   #4
jeep06
Ditto... mine reads the same as yours with 6qts.
Flame Red 2005 Rubicon Unlimited, 4.0L, 6sp, dual tops, Valvoline VR-1 10w30 engine oil/M0-090 Mopar filter, Amsoil Synchromesh 5W30 trans. oil, IPF 920hc head light conversion with PIAA Xtreme White plus bulbs, PIAA Xtreme White Plus H-3 fogs, Armadillo front/rear bumper caps and Olympic grille guard. Amsoil SevereGear 75W140.
jeep06 is offline   Reply With Quote
Old 07-29-2008, 01:58 PM   #5
shadows_lair
Thanks all
I appreciate the feedback. I'm following your advice and I'll probably re-mark the dipstick as a personal reminder.
Thanks again,
Mike H.
Glock Forum
