Oil leaks! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Oil leaks!
FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectBead Lock Wheels! Raceline, Trail Ready, & Trail-GearIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-12-2015, 10:58 AM   #1
gavone1976
Oil leaks!
Looks like I need a new valve cover gasket,oil pan gasket and 2 pinion shaft seals.My mechanic quoted me 187 in parts and 532 in labor.Can I do these repairs in my driveway.It looks like the biggest pain might be the oil pan gasket.
Any input or pointers would be appreciated.
04 Rocky Mountain Edition,automatic, 57000 miles.
gavone1976 is offline   Reply With Quote Quick reply to this message
Unread 06-12-2015, 11:14 AM   #2
biffgnar
biffgnar's Avatar
Hard to believe all of those are bad at the same time. Are the quotes on the high side? Yes. Are they offensive? Probably not. Are all of those things doable by some one with basic skills and tools? Absolutely.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 06-12-2015, 11:22 AM   #3
gavone1976
I was thinking the same thing that all these gaskets would go bad together.I am thinking about replacing valve cover gasket and the pinion shaft seals and then see if the oil pan gasket is actually leaking.
Unread 06-12-2015, 12:19 PM   #4
gavone1976
the estimate for the pinion shaft oil seals list 2 of them.One says all applicable models and the other says Dana model 44 with tru-lok.Is there two of them on the rear axle?
Unread 06-12-2015, 12:29 PM   #5
gavone1976
Unread 06-12-2015, 12:47 PM   #6
biffgnar
biffgnar's Avatar
No
Unread 06-12-2015, 03:51 PM   #7
Nee
Junior Member
First degrease oiled areas and be sure yourself. Second, watch related how to YouTube vids and finally go online and search for a free PDFs download of FSM
Nee is offline   Reply With Quote Quick reply to this message
Unread 06-12-2015, 08:20 PM   #8
Warhound
Junior Member
yeah oil pan and valve cover are easy to do in the driveway, pinion is if you know how to set up a diff.
Warhound is offline   Reply With Quote Quick reply to this message
Unread 06-13-2015, 07:30 AM   #9
biffgnar
biffgnar's Avatar
True that that is the "right" way to do the pinion seal, but lots and lots of people do it the "wrong" way (where no need to know anything about diff setup) with no problems at all.
