Oil Leak between Engine and Transmission Question - JeepForum.com
post #1 of 10 Old 07-14-2008, 05:13 PM Thread Starter
alexr40
Hi guys
I noticed a oil leak that stops when the jeep is OFF. but its dripping fast when its turned on.
I got under the jeep and i noticed that its leaking from like a cover that has a hole on it.. I bet underthere is the REar engine seal or something. here are some pics
I Cleaned it so theres no oil in the picture.
its leaking by that hole/gap there in the middle of that cover. What's that gap for? Its leaking from inside there.
I dont know if put some silicone there to hold a little until I get it fixed. I dont know the purpose of that hole. anybody knows?
1998 Jeep Wrangler 2.5L Turbo @11psi
Locked Front & Rear, 4.56s, 4:1 low range with 2LO. 35's with Beadlocks .
2005 WK Limited 4.7L - 4x4 (QT-II)
2" RC Lift, 265/70/17 BFG AT/KO, OME Rear Shocks, Saguaro Shackle Mounts, Mopar OEM Hitch
alexr40 is offline
post #2 of 10 Old 07-14-2008, 05:19 PM Thread Starter
alexr40
also... i bought a BAR's LEAK Engine oil STOP LEAK.
WHy you experienced guys recomend? Should it work? Should I add it and see if it helps unti I can get to the problem?
I read somewere Bar's are one of the best. There are other junks that clogs stuff.
Please feed back.
I hope its not the real seal. Heard its very expensive and the trans or engine needs to be removed
alexr40 is offline
post #3 of 10 Old 07-14-2008, 05:27 PM
UTWeezul
It is probably the rear main seal and you don't have to remove the engine or trans to replace it. You have to drop the oil pan and the seal is in the bottom of the engine. I don't have a write up on hand but there are quite a few out there.
35" MTR Kevlars
TNT Phantom Fenders/PSC Comp Cut corners
HP30 and 8.8 w/ lockers
103" Wheelbase
UTWeezul is offline
post #4 of 10 Old 07-14-2008, 05:34 PM
jclark50
From the picture it looks like the oil pan seal. They don't cost too much. I changed mine a month ago and it was a pain in the ***. The oil pan wouldn't fit out because the exhaust pipe. I un-hooked the exhaust at the engine and it still wouldn't fit out. I had to drop the belly up to detach the exhaust under there. I know there has to be an easier way.
jclark50 is offline
post #5 of 10 Old 07-14-2008, 05:35 PM
never monday
http://www.dailydriventj.com/forum/viewtopic.php?t=643
never monday is offline
post #6 of 10 Old 07-14-2008, 07:18 PM
kloppk
That's true for the 4.2 and the 4.0 but NOT the 2.5.
The 2.5 uses a 1 piece RMS which requires pulling the tranny to replace it.
kloppk is offline
post #7 of 10 Old 07-14-2008, 07:23 PM
kloppk
What color is the fluid that's leaking?
Brown/black-ish or red-ish?
Red-ish would be you automatic transmission input shaft seal around the torque converter.
Brown/blackish could be your engines...
- rear main seal (RMS)
- the very back of your pan seal
- or your valve cover gasket. Oil can drip down the back of the engine and appear where you see it.
kloppk is offline
post #8 of 10 Old 07-14-2008, 09:11 PM
UTWeezul
Didn't realize he had the 2.5L. My bad
35" MTR Kevlars
103" Wheelbase
UTWeezul is offline
post #9 of 10 Old 07-21-2008, 12:12 PM
SpoiledRotten
SpoiledRotten's Avatar
Originally Posted by never monday View Post
Very good writeup. I'll keep that for future reference.
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #10 of 10 Old 12-21-2014, 06:24 PM
RicanGen20T
My 97 Sahara stars gushing out red fluid in between the engine and trans when I put in gear. What could that be?
RicanGen20T is offline
Engine oil leak! Front diff sweatl leak Mr.Unlimited JK Wrangler Technical Forum 11 09-22-2009 08:49 PM
New Leak! Transmission Oil!!! Question alexr40 TJ Wrangler Technical Forum 1 07-15-2009 07:49 PM
Transmission Leak.... sauce90yj YJ Wrangler Technical Forum 2 05-03-2007 07:43 PM
Transmission Leak ecrabb YJ Wrangler Technical Forum 4 07-11-2005 07:40 PM
Transmission leak mitchj01 YJ Wrangler Technical Forum 2 03-10-2003 04:14 PM
