Oil Change Valve?? - JeepForum.com
post #1 of 5 Old 01-06-2010, 03:23 PM Thread Starter
Thexonexkid
Thexonexkid's Avatar
1986 XJ Cherokee
Oil Change Valve??
So has anyone had an experience with an oil change valve. With the skid plate its always a challenge changing the oil both getting the bolt out and also getting the oil to drain not on top of the skid plate (there is a hole but its not perfectly aligned and I have to shove cardboard up there and move it around)
So oil change valve??
QuickOilDrainValve.com - the best way to change oil
this is by no means the brand I am going to use (idk anything about them) and if you don't either there is a link to what I am talking about.
Any input is nice thanks.
84 CJ7 Rebuild:
Thexonexkid is offline
post #2 of 5 Old 01-06-2010, 03:24 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
lots of folks use Futomo drain valves.
Fumoto Engine Oil Drain Valve Installation - Jeep
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 5 Old 01-06-2010, 03:39 PM
SamPsychoWise
Hey, I have a one. I also have Skidrow Eng/Trans Skid plate. This drain works well with it, oil drains perfectly though the cut out in the skid plate. Only con that I have is.... It drains slowly. Just make sure your oil is nice and warm.
I got sick of fighting with a rachet, extension & swivel socket to get the drain plug out.
I think they are the same company
SamPsychoWise is offline
post #4 of 5 Old 01-06-2010, 04:30 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
I also have a Fumoto and it works well, but a bit slower on the draining because of the bore size of hole in valve.
GOLENJEEPTJ is offline
post #5 of 5 Old 05-02-2010, 05:41 PM
Polecat
Polecat's Avatar
I put one of these on the last time I changed my oil. Haven't used it to drain yet but I am sure it will be less messy with the Skid Row skid I have under there.
Polecat is offline
Lifter tick, valve chatter, sticky valve..... brtt485 YJ Wrangler Technical Forum 28 09-28-2012 11:07 PM
Needing to change valve cover gasket Cards89YJ YJ Wrangler Technical Forum 5 12-06-2009 11:58 AM
Leaking oil after change, rear main seal? Valve cover gasket? ZeroGravity YJ Wrangler Technical Forum 9 10-22-2009 04:39 PM
Broke elbow on pcv valve on front of valve cover... 99JeepWrangler TJ Wrangler Technical Forum 12 01-01-2009 01:17 PM
tapping after valve cover gasket change olyjeep YJ Wrangler Technical Forum 8 04-05-2007 04:09 PM
