oil capacity 4.0 - JeepForum.com
post #1 of 11 Old 10-07-2004, 05:38 PM Thread Starter
snofrog
oil capacity 4.0
what is my oil capcity on my 4.0 ? i put in 5 and she look`s a little low.Thank`s Mark
snofrog is offline
post #2 of 11 Old 10-07-2004, 05:40 PM
JSBlu974X4
manual says 5 but if its low add more.
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #3 of 11 Old 10-07-2004, 05:40 PM
RCHavok797
RCHavok797's Avatar
6 quarts and it says it in the owner's manual.
2005 LJ Impact Orange 4.0L Automatic (Tigger) - new ride
1991 YJ Sahara 4.0L Automatic
1978 Dodge Lil Red Express - work in progress
RCHavok797 is offline
post #4 of 11 Old 10-07-2004, 05:45 PM
JSBlu974X4
oops my bad, hit the 5 instead of 6....but either way just add until the level says its fine
post #5 of 11 Old 10-07-2004, 05:47 PM Thread Starter
snofrog
2 answers at 6 is good enough for me .Thankyou M
snofrog is offline
post #6 of 11 Old 10-07-2004, 06:17 PM
JeepCrawler_98
JeepCrawler_98's Avatar
6 quarts
New kid on the block!:
JeepCrawler_98 is offline
post #7 of 11 Old 10-07-2004, 09:51 PM
Stick
Stick's Avatar
I just did an oil change (went from regular to synthetic), and 6 quarts put me just above the safe band on the dip stick.
"Firearms are second only to the Constitution in importance; they are the peoples' liberty's teeth." -George Washington, United States President and Founding Father.
Stick is offline
post #8 of 11 Old 10-07-2004, 11:17 PM
JeepCrawler_98
Is that right after? If so it's normal for it to be a little over since the filter hasn't fully saturated yet.
post #9 of 11 Old 10-09-2004, 10:23 PM
halfmoonclip
That may explain why you only get 5 qts back OUT, but all my I-6s have read a little over full with 6qts even after filter fill. Not to worry.
Moon
'04 Rubi, manual, usual options, Hella H-4s, any range lockers, Randy's booster seats, Oly pushbar, 245/75R16 BFG
'09 Audi A4 Avant- my bride's schnellpuffenpanzer
'12 Ford Focus-the sure way to get good Jeep mileage
'07 Dodge Caliber R/T AWD-da kid's ride
Goodbye Old Blue XJ; 10+yrs, 100K+ miles; virtually trouble free; Long may you run!
halfmoonclip is offline
post #10 of 11 Old 05-13-2016, 11:45 AM
damnjeep
I know I am about 12 years late on a response here, but I put 6 quarts of oil in my 2000 jeep TJ last weekend as the manual stated. Weird there is that I had no leaks or anything up to that point, but only 5 quarts came out when i changed it. (I didn't change my oil previously, a shop did). I noticed a couple drops of oil on the ground, and it was coming from valve seal Looks like I am in the 'Do not overfill" section. The manual says 6, but that is wrong as it showing overfill. It should be around 5.5.
damnjeep is offline
post #11 of 11 Old 05-13-2016, 12:15 PM
JStMarie
JStMarie's Avatar
The missing quart got burnt off or 'escaped' onto the ground. Not unusual.
My 4.0 takes 6 quarts. I put 5+ in, start her and let her run for about 60 seconds. Shut her down, let her sit for 5, and you will see she needs another 1/2 quart to top her off.
My 2.5 takes 4 quarts, same deal. Put in 3+ she looks full on the dipstick. Run her for a minute, let her sit. Check again, needs a bit more to top her off to full.
Patience
JSt.Marie
'06 Jeep Wrangler, 65th Edition, stock.
'98 Jeep Wrangler, stock.
JStMarie is online now
8.8 capacity motorhead0320 YJ Wrangler Technical Forum 5 11-14-2007 11:56 AM
D44 Capacity ribbitt617 TJ Wrangler Technical Forum 2 01-03-2007 01:12 PM
Oil Capacity 4.0 billy boy TJ Wrangler Technical Forum 3 12-01-2006 11:12 AM
Oil capacity of 8.8 sequel YJ Wrangler Technical Forum 6 10-15-2006 07:58 PM
4.0 oil capacity? ian-X TJ Wrangler Technical Forum 2 10-04-2003 12:15 PM
