Official "I have relocated my rear springs" thread - JeepForum.com
post #1 of 15 Old 09-30-2009, 02:30 PM Thread Starter
CCJ
Let's play the Do Not's:
-this thread is not to discuss CA's
-this thread is not to discuss shocks
-this thread is not to discuss springs
-this thread is not to discuss axles
So what's this thread for?
This thread is for those that have already performed a rear spring relocation, to discuss their results, ask questions to others that have also relocated springs, & to post if you noticed a change in ride quality both on the road and off.
If possible, when posting please take the time out to fill these in:
-How tall of lift did you have before the install of the rear springs?
-How tall of lift do you have after the install?
-Would you do it again if you total your Jeep and get another Jeep?
-Why or why not to the question above?
-What spring relocator kit did you use?
-How long have you had your springs relocated?
-What problems did you run into during your install?
-How often do your drive on road vs off? (rough percentage please)
Thanks in advance!
CCJ is offline
post #2 of 15 Old 09-30-2009, 02:35 PM Thread Starter
CCJ
And yes, if you run coilovers in the rear that does count.
CCJ is offline
post #3 of 15 Old 09-30-2009, 03:06 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
DEAD.
TheBoogieman is offline
post #4 of 15 Old 09-30-2009, 04:42 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
DEAD.
well, at least its *Official*
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 15 Old 09-30-2009, 04:59 PM Thread Starter
CCJ
Alright the both of ya. LOL GTFO my thread please.... Except for you Unlimited you helped with the M10 bolt idea. You sir can stay. LMAO
CCJ is offline
post #6 of 15 Old 09-30-2009, 05:05 PM
Unlimited04
ok ok, i'll contribute something worthwhile - some other threads on the subject
http://www.jeepforum.com/forum/f9/re...cators-684217/
http://www.jeepforum.com/forum/f9/up...wesome-796470/
http://www.jeepforum.com/forum/f9/re...or-kit-856163/
Useful Write-Ups:
Funny:
post #7 of 15 Old 09-30-2009, 06:45 PM Thread Starter
CCJ
Yea, I've read those before. I was really hoping to find someone with stock or 2.5" or less lift. Ah well. My thread is failing by the hour. LOL
Thanks for links though captain!
CCJ is offline
post #8 of 15 Old 09-30-2009, 08:06 PM
cmoore
cmoore's Avatar
I've removed my springs for coilovers f&r.
-Before: Rig had a 4" of suspension lift and 35's
-After: Has ~4" of suspension lift (same as before only with a 9" stretched wheelbase) and is rolling 39.5's.
-Yes I would do it again.
-It is more stable and performs better in all terrains now
-Used Poly performance's coilover mounts f&r
-Rig has been done about 13 months and wheeled in 6 states since.
-see build thread in my sig
-I try to wheel a couple weekends a month (and occasionally dd so I can wheel on my lunchbreak: http://www.youtube.com/watch?v=rAajxGmsRoc )
hth.
98 XJ:4.0, AW4, HP30/8.25 4.56 Spartan/LSD, alloy shafts & joints, HD steer, SYE/CV, skids, RADesigns gated shifter, RE mix n match lift, 35"mt/rs, THOR guards F&R, weld-in custom rockers & stiffeners, custom front bumper, orfab rear bumper, THOR cowl induction, on board air, on board welder, etc
cmoore is offline
post #9 of 15 Old 09-30-2009, 08:43 PM Thread Starter
CCJ
This helped greatly. Thanks for post.
CCJ is offline
post #10 of 15 Old 09-30-2009, 10:40 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
i relocated mine, it was awesome. it was also too tall though and i dropped it back down.
My builds:
and
or follow us on
spyder6 is offline
post #11 of 15 Old 10-01-2009, 07:18 AM Thread Starter
CCJ
Spyder, what did you use to relocate your rears?
CCJ is offline
post #12 of 15 Old 10-01-2009, 07:23 AM
spyder6
spyder6's Avatar
2010
AEV's stuff
My builds:
and
or follow us on
spyder6 is offline
post #13 of 15 Old 10-01-2009, 07:26 AM
dbbd1
dbbd1's Avatar
Mudb8 moved mine (my welding skills are marginal). I have the RC 2.5" lift and am very happy. Gained some compression room, better ride.
See here...
http://www.jeepforum.com/forum/f9/lo...antage-852221/
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #14 of 15 Old 10-01-2009, 07:41 AM Thread Starter
CCJ
AEV's stuff
ty for info
See here...
nice. Thanks for chiming in
CCJ is offline
post #15 of 15 Old 10-01-2009, 09:42 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I'm planning on relocating my rear springs over the winter.
My plan is to cut the coil mount off. Then i'm probably going to notch the rear frame portion to run ballistic fab's upper mounts
Something similar to what is seen here.
http://www.jeepforum.com/forum/f9/up...tretch-822417/
Originally I was thinking of cutting the frame mounts off and move them back, but I think I will just end up making new control arms out of square lower arms and round upper arms and reuse the currie JJ's from my Clayton kit for the time being.
Not 100% sure where the shocks will be mounted. I will have to see how much stretch there will be. I may notch the frame and run F250 or similar mounts.
http://www.ballisticfabrication.com/...rs_p_1478.html
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
4" front 3" rear springs. What do i need Carolinatj906 TJ Wrangler Technical Forum 25 02-06-2010 10:32 PM
Relocated License Plate "no more flapping" Randy77358 YJ Wrangler Technical Forum 4 05-27-2009 04:37 AM
3" springs bad idea? with a 2.25" bb rear. SOLIDJP44 TJ Wrangler Technical Forum 7 01-09-2009 04:31 AM
1.5" springs rear 2" springs front Goobersbro YJ Wrangler Technical Forum 4 11-19-2008 10:31 PM
4" springs in front with 3" springs in rear? will it work? saggy front! rivers edge JK Wrangler Technical Forum 6 09-07-2007 05:40 AM
