off size spare? - JeepForum.com
post #1 of 8 Old 07-15-2007, 09:26 AM Thread Starter
monkeychrist
off size spare?
Hello,
I got a deal on 4 31x10.5-15's for the jeep. The fifth tire, the spare, is a stock 30. Is it still usable as a spare, just for emergency purposes, or will it cause too much tilt?
Originally Posted by athos76 View Post
...but one day while driving, I heard a twang and saw a little orange bungee go shooting off into traffic...
monkeychrist is offline
post #2 of 8 Old 07-15-2007, 09:43 AM
marc1kim
If you've got limited slip axles it's not recommended to have two different size tires.
marc1kim is offline
post #3 of 8 Old 07-15-2007, 11:17 AM
Scotch740
Scotch740's Avatar
If you only have a LSD in one axle you can always swap the 30 to the open axle. Other than that you will be fine.
Edit: The problem is not the tilt, which you probably won't even notice. It is that one shaft will be turning more than the other. With a LSD or a locker they will be locked together and it will cause big problems.
Scotch740 is offline
post #4 of 8 Old 07-15-2007, 11:26 AM
SGT Superman
SGT Superman's Avatar
I hate to see people driving around with a stock spare. Like the others said, if you dont have lockers or a limited slip you will be fine for an emergency, but please get a full size on there soon.
Now you know, and knowing is half the battle. G.I. Joe!
Green Jeep Club Member #174
GO COUGS!
SGT Superman is offline
post #5 of 8 Old 07-15-2007, 11:32 AM
bairy
I wonder what the rolling diameter change is on a fully aired up 30, compared to an aired down 31
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #6 of 8 Old 07-15-2007, 11:38 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Tire diameters don't change like balloon diameters do when air pressures are varied. The circumference changes such a small amount after being aired down to be totally inconsequential.
Getting
Jerry Bransford is offline
post #7 of 8 Old 07-15-2007, 11:41 AM Thread Starter
monkeychrist
cool, thanks guys. The 31's are just to last long enough until i can do the lift and 33's all at once. The stock 30's were bald when I got the jeep and like I said, got a good deal on the 31's, but it was only for four of them.
post #8 of 8 Old 07-15-2007, 05:21 PM
98greentj
it's only a half inch, it won't matter
98greentj is offline
What size of spare do I need to use? OzarkOutdoors TJ Wrangler Technical Forum 24 03-15-2010 09:36 PM
Spare Rim size denalione YJ Wrangler Technical Forum 1 04-18-2009 03:30 PM
What size spare? rdhclark TJ Wrangler Technical Forum 5 11-21-2008 11:47 PM
Spare different size Morgen251 TJ Wrangler Technical Forum 43 07-18-2007 10:34 AM
Spare Size ?? blevinsbulldog YJ Wrangler Technical Forum 8 02-04-2006 11:46 AM
