Oem rear axle - JeepForum.com
post #1 of 3 Old 07-14-2010, 06:48 PM Thread Starter
redo4x
Oem rear axle
What will be included if you order one of these rear axles? I was looking at the last one.
https://www.jeepoemparts.com/2004-je...ler-parts.html
It looks like the link does not carry you all the way. It's a rear dana 44 housing, 4.11 ratio, 03-06 tj
redo4x is offline
post #2 of 3 Old 07-14-2010, 07:12 PM
robncar
robncar's Avatar
Your link no workie...
AXLE HOUSING, TJ Series, Dana Model 44 Axle, 4.11 Ratio
03-06 $990.00 $754.38
I'd call them and ask if it were me.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 3 Old 07-14-2010, 07:26 PM Thread Starter
redo4x
The link did not send you all the way. It appears to be just the housing but specifies gears. Just wondering if anyone had bought one. Definately worth a phone call.
redo4x is offline
oem , rear axle , complete , assembly , replacement , info , information , d44 , dana 44
Rear Axle / Rear Tire Clunking After Exiting Expressway czar97 TJ Wrangler Technical Forum 8 12-12-2011 09:18 PM
Should the Front Axle & Rear Axle be off centered to the passanger side by .5"? Lemmiwinks TJ Wrangler Technical Forum 3 07-07-2009 09:27 AM
Solid Axle Hd 44 Rear Axle Assembly SuperWade2 TJ Wrangler Technical Forum 128 06-05-2009 12:01 AM
Tire/Rear Axle question....out of alignment, rear axle "turned". (Thrust Angle) Sparty TJ Wrangler Technical Forum 5 09-19-2007 02:23 PM
Rear trackbar bracket? Drilling? Rear axle shift thebulkinator TJ Wrangler Technical Forum 5 04-03-2005 08:17 AM
