OEM fog lights for TJ 2000 in TJ 2006 - JeepForum.com
post #1 of 8 Old 03-28-2007, 09:48 AM Thread Starter
maimo
I have a pair of OEM fog lights for a TJ 2000, and I want to put in my TJ 2006, is there any problem with that?, I mean with the instalation wire Kit and the swith?
Thanks
maimo is offline
post #2 of 8 Old 03-28-2007, 09:50 AM
RLD831
RLD831's Avatar
There shouldn't be a problem. Especially if the lights have their own harness like the set I bought a while ago. If not, then your 06 probably has a harness built in.
RLD831 is offline
post #3 of 8 Old 03-28-2007, 10:20 AM Thread Starter
maimo
OK, thanks. I have the harness with the switch for the dash. (I have seen the kit for TJ 2006 and the switch is for installation in the steering wheel) thats why I doubted
maimo is offline
post #4 of 8 Old 03-28-2007, 11:19 AM
jeeptj19992001
the pig tail on the lights are diffrent then the 06 pig tail they plug into. changed them in 05 i belive
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #5 of 8 Old 03-28-2007, 11:46 AM Thread Starter
maimo
but If I have all the Kit: lights, wires and switch? is there a problem with the pigtails?
maimo is offline
post #6 of 8 Old 03-28-2007, 11:55 AM
Grewe02
Guns > Swords
Grewe02's Avatar
1981 CJ5
Just splice the wires. Don't worry about the amperage. You'll be fine.
Andy, KD8EIA
Originally Posted by Jetscuh
Grewe02 is offline
post #7 of 8 Old 03-28-2007, 12:02 PM
jeeptj19992001
if you have the WHOLE kit, then you are ready to rock
post #8 of 8 Old 03-28-2007, 03:14 PM Thread Starter
maimo
OK, thanks
maimo is offline
NP231 from a 2000 TJ fit a 2006 LJ? NavinRJohnson TJ Wrangler Technical Forum 1 10-29-2009 11:40 AM
2006 hard top on a 2000 tj - wiring help leukus TJ Wrangler Technical Forum 3 10-24-2009 04:40 PM
2006 Rubi Moab Wheels Fit My 2000? Hunta TJ Wrangler Technical Forum 8 01-20-2009 08:55 PM
Lug diameter 2000 vs 2006 bruker TJ Wrangler Technical Forum 2 11-28-2006 02:02 PM
2000 Wrangler No park Lights or Dash Lights Deb04 TJ Wrangler Technical Forum 2 04-06-2004 10:28 PM
