Odometer errors - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Odometer errors
ExtremeTerrain GROUP BUY: Barricade Rear Bumpers/Tire CarrIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSteering and more from Ruffstuff!
Unread 08-20-2014, 11:21 AM   #1
BillMurry
Odometer errors
Got a problem with the Odometer. The PO told me that something was wrong with the original instrument cluster and when they installed a replacement, the ODO reading stored in the cluster didn't match the number stored in the computer and so my ODO reads zeros all the way across. As a matter of fact it even shows lit up zeros when the key is OFF. PO said they took it to a dealer who said that there was a computer work around that could be done for $800 and that the two milages were 85,000 and 150,000 and he'd have to pick one. Well he didn't know which it should be but assumed the condition of the Jeep told him it should be 85,000. I don't know about all that. I've replaced clusters before in different vehicles and never ran into what they suggest is happening.
Does this sound correct. Is there anything I can do to fix it?
BillMurry is offline   Reply With Quote
Unread 08-20-2014, 11:43 AM   #2
Neil F.
It is correct that mileage is stored seperately in the pcm and cluster. If you obtain a used cluster it will have the mileage from the donor vehicle. I am not sure why yours is reading zeros
Neil F. is offline   Reply With Quote
Unread 08-20-2014, 11:59 AM   #3
BigRodney
I've read about this before. It's done on purpose so any Joe blow can't just change the odometer reading. I'm no expert but I think only the dealership can resolve this.
BigRodney is online now   Reply With Quote
Unread 08-20-2014, 01:02 PM   #4
BillMurry
I'm going to attempt to swap another cluster in. I wrote that the odometer is suspect on the title when we bought it so I'm really not too worried about the actual mileage. Not to mention, technically speaking after ten years old mileage really doesn't matter much.
It's just be nice to have a tripometer that worked correctly and whatever else come through that display and not have it draining the battery when off.
Unread 08-20-2014, 02:35 PM   #5
Neil F.
The dealer cannot change the cluster mileage
http://www.jeepforum.com/forum/f9/re...t-help-983634/
http://www.jeepforum.com/forum/f9/mi...luster-299939/
http://www.jeepforum.com/forum/f9/pc...ssues-1142808/
http://www.jeepforum.com/forum/f9/od...luster-191326/
