Odo vs Tire Size? - JeepForum.com
post #1 of 9 Old 02-04-2011, 12:13 AM Thread Starter
rtiburon
Odo vs Tire Size?
Don't the odometers on TJs count off wheel rotation like most cars? It's a silly question but if that's the case won't the odo under-report miles driven the larger the tire size??
I should know this but I thought I'd throw it out there.
rtiburon is offline
post #2 of 9 Old 02-04-2011, 01:06 AM
asknight
Yes. That's why the speedometer gear market stays so busy.
http://www.jeep4x4center.com/jeep-speedometer-gears/
asknight is offline
post #3 of 9 Old 02-04-2011, 02:04 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
Yup.
TheBoogieman is offline
post #4 of 9 Old 02-05-2011, 09:23 AM
noise_maker
Were these always so expensive?
Just seems 75 for a little plastic gear is a bit much. I though I remember them being allot cheaper
(Of course before I needed a new one)
noise_maker is offline
post #5 of 9 Old 02-05-2011, 09:48 AM
Neil F.
The price was around 30 but it shot up 2-3 years ago. Some ratios faster than others.
Neil F. is offline
post #6 of 9 Old 02-05-2011, 11:40 AM
TheBoogieman
Deeply Disturbed
post #7 of 9 Old 02-05-2011, 02:41 PM
monkeee2002
So..... larger tires equal a lower mileage being reported to the odometer, correct? (without re-gearing the axles or the speedometer)
.... Makes me wonder how many miles my Jeep REALLY has now.....
The skinny pedal on the right is my friend. the gas gauge is not.
monkeee2002 is offline
post #8 of 9 Old 02-05-2011, 03:39 PM
Sccafire
Same here. I had stock Rubicon gearing with 35's for 4 years. I went to 5.13's and now the speedometer reads faster. I guess I will catch up eventually.
Scott
"life is good at 2 MPH"
Sccafire is offline
post #9 of 9 Old 02-05-2011, 04:38 PM
dscabra
I use this on-line calculator -- doesn't account for gears, but will tell you relative differences in tire sizes.
http://www.discounttire.com/dtcs/infoTireMath.dos
dscabra is offline
A couple of tire model and size questions (what size with stock gears) GraysonJeep JK Wrangler Technical Forum 17 07-22-2010 03:36 PM
Tire Size and Wheel Size Guess user77877 JK Wrangler Technical Forum 4 06-28-2009 12:22 PM
stock tire size vs bigger tire size jtaylor83 TJ Wrangler Technical Forum 4 11-14-2008 09:20 AM
Opinion about tire size vs. Lift kit size awol09 TJ Wrangler Technical Forum 25 09-29-2008 07:17 PM
Spare Tire Size vs Tire Size Roadstar TJ Wrangler Technical Forum 2 02-20-2003 12:14 PM
