I just replaced my airbags and airbag controller. I'm having odd issues. Turn on my headlights and all my gauges dive and my windsheild wipers come on.
It sounds like you have two plugs swaped around Being in the car audio bizz for 20 years I have see plugs go together and not being the right conection . check your plugs.
No dis-respect, but it is really hard to swap anything around. They all have specific connectors. This problem actually started right after my accident before the airbag swap.
check you grounds sounds like te lights are pulling all the ground away from everthing else, dash grounds, under hood, add a ground, if you can't find the proper one...:wave:
I was only making a suggestion I replaced a under dash main harness for a friend with an eagle talon once and the damn thing had 8 identical plug in the harrness, all within 10 inches of each other.
good suggesstion on the grounds!
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
