OBD II Codes P0340 and P0344 - JeepForum.com
post #1 of 2 Old 01-04-2008, 04:53 PM Thread Starter
prljeep
2005 Jeep Wrangler X - 53k- I6 - MT
My check engine light came on on the ride home from work...figured it was a loose vacuum line because my cruise control would not work. However, it would downshift very roughly.
When I got home, I turned it off and tried to start it again- nothing. Just cranking. I did the key trick and got the following codes P0340 and P0344. Looks like they are camshaft position sensor related??? Any thoughts since they appear to be the same code? 53k and I am all ready losing one??
Anything else you can tell me about these codes???
Where would you start?
prljeep is offline
post #2 of 2 Old 01-04-2008, 07:02 PM
creaky70
Sounds like the cam position sensor (AKA "stator" & "coil pickup") took a dump. I have heard of instances where the magnet falls off the mounting plate and falls into the distriburtor.
creaky70 is offline
CEL P0344 - anyone? dalby TJ Wrangler Technical Forum 7 02-28-2011 06:03 PM
Camshaft PS? P0344 RVA_TJ06 TJ Wrangler Technical Forum 2 12-16-2009 06:36 AM
P0344 Code Keeps Coming Back BWs TJ Wrangler Technical Forum 4 08-25-2009 09:44 PM
OBD II Codes p0340 and p0344 prljeep TJ Wrangler Technical Forum 5 01-16-2009 05:45 PM
Possible resolution for P0340 and P1391 codes 02tjsport TJ Wrangler Technical Forum 0 06-14-2007 06:15 PM
