OBD Code P0420(M) - possible causes? - JeepForum.com
post #1 of 9 Old 11-30-2008, 07:12 PM Thread Starter
Kiwi Jeeper
I have had my cat converter and front O2 sensors replaced last year (about 12 months ago). Since then I have driven about 12k kms.
This weekend I got the check engine light and the code that has come up is P0420(M) - catalyst converter efficiency below threshold.
What could be causing this? Surely an O2 sensor or cat converter can't go bad in about 12k??? TJ has done 94k kms total.
I did clear the code and it hasn't come back this afternoon (only driven for like 5 kms).
I wanted some ideas before throwing money replacing parts. Thanks.
'12 JK Rubicon V6 3.6L
'15 KL Trailhawk V6 3.2L
Kiwi Jeeper is offline
post #2 of 9 Old 11-30-2008, 07:55 PM
durango-bob
2006 WK
That would be the rear O2 sensor.
durango-bob is offline
post #3 of 9 Old 11-30-2008, 08:36 PM
ktroth
ktroth's Avatar
2011 JK Wrangler
umm like it says unfortunatly cat or 02 sensor
2011 JKU Rubicon
02 TJ Sport - Sold
ktroth is offline
post #4 of 9 Old 11-30-2008, 08:38 PM Thread Starter
Kiwi Jeeper
Thanks. Looks likely given that it was not changed (everything else was changed in the exhaust starting from cat converter and back).
post #5 of 9 Old 11-30-2008, 08:40 PM Thread Starter
Kiwi Jeeper
I was looking for an "AND" answer
Don't want to change both (and spend unnecessary $$, in case only one is busted). The question was more around which one of the components is more likely to be the cause.
post #6 of 9 Old 11-30-2008, 08:47 PM
ktroth
ktroth's Avatar
2011 JK Wrangler
if the rear o2 sensor was not replaced then that must be the culprit. it sucks. its a trial and error system. if its not one thing then its the other. good luck chasing the problem.
2011 JKU Rubicon
02 TJ Sport - Sold
ktroth is offline
post #7 of 9 Old 01-27-2009, 10:34 AM
johnk667
P0420 Code
Hello, I am having the same check engine light code P0420. Did you ever find what the problem was?
john
03 Rubicon
johnk667 is offline
post #8 of 9 Old 03-06-2009, 03:53 PM
saintv90
I got the same error on my 04 Grand cherokee. I assume it's a o2 sensor...actually I hope it's an o2 sensor.
saintv90 is offline
post #9 of 9 Old 03-07-2009, 01:51 AM Thread Starter
Kiwi Jeeper
In my case it turned out to be improperly done up gas tank cap. I don't know how that told the computer about cat efficiency. But it has not come back again, and I have not changed anything.
Code P0420 and Rattling Underneath valacech TJ Wrangler Technical Forum 11 02-17-2011 01:02 PM
It's back!!! code p0420 convertor low eff. vosevichs TJ Wrangler Technical Forum 1 11-05-2010 09:51 AM
98 wrangler 4cyl: code P0420-Cats? WhtSoxfan TJ Wrangler Technical Forum 1 11-16-2009 11:31 AM
trouble codes P0420 & P0432 KNB7638 TJ Wrangler Technical Forum 1 01-03-2008 02:31 PM
Check Engine Code p0420 gtospeeding TJ Wrangler Technical Forum 12 05-08-2007 11:43 PM
