O2 simulator question! - Page 2 - JeepForum.com
post #16 of 27 Old 10-23-2013, 11:23 AM
TroubleNEO
I know a guy with hollow cats, has a Jeep that looks exactly like mine and it runs great.
Looking for: 03-06 interior plastic trim. PM me.
TroubleNEO is offline
post #17 of 27 Old 10-23-2013, 03:07 PM
GSP
2015 JK Wrangler
These will work and eliminate check engine light:
Dorman/Spark Plug Non-Fouler $9
http://www.autozone.com/autozone/par...720771_0_2826_
All my vehicles but one has dead cats.... this works...
GSP is offline
post #18 of 27 Old 01-24-2014, 08:42 AM
durnjeep
Why would you disregard what the manual says? If it says it affects fuel/air ratio than it does. And it DOES. I was having an idle issue and had codes p0141 and p0161 and replaced both downstream sensors, and voila, no more idle issue. These hillbilly mechanics that "went to school" need to go back to school.
durnjeep is offline
post #19 of 27 Old 01-24-2014, 02:03 PM
catsknr
These work great. I have them on my Jeep and my S-10, only my sensor was too long so I had to use two and drill out the bottom of the top fouler. Worked like a champ.
/l ,[____],
l-L -OlllllllO-
()_)-()_)-o-)_)
Just Empty Every Pocket
catsknr is offline
post #20 of 27 Old 04-12-2014, 08:36 PM
HAFICON
Old thread I know.. *L* found this to be some what entertaining, I am just reading up about to replace full exhaust on my TJ
315/70/17 Duratrac on MB Wheels
AEV 2.5 with M.O.R.E 1" body lift
Viair 450c, ARB Air lockers,
4.88's and TNT truss.
My build thus far.
HAFICON is offline
post #21 of 27 Old 09-09-2014, 11:58 AM
JohnyRRR
How do these work, I would think by moving the O2 sensors into colder air and out of the exhaust stream they would think its cold out and increase richness by adding more gas? just curious
2010 4door sport 6-speed
JohnyRRR is offline
post #22 of 27 Old 09-10-2014, 11:08 AM
joe_jeep
on a 97 u dont need an o2 simulator, or to remove the cat.
it will empty itself soon enough.
or buy a magnaflow hi flow cat, and put it back together.
glfwda #6624
2005 rubicon sahara lj #592
joe_jeep is offline
post #23 of 27 Old 09-10-2014, 01:15 PM
willis36
willis36's Avatar
I have not had a magnaflow cat last more than two years before blowing chunks out the tailpipe.
willis36 is offline
post #24 of 27 Old 09-10-2014, 01:29 PM
chmo
I do not think the "air" reaching them is much "colder" if you use those spark plug non foulers on post cat O2s ... just less measured partikel stream per time unit. (as if the cat is still there)
And the air fuel mix gets mainly adjusted with help of the PRE cat O2s ... which you should not touch!
LOL
"The more I know, the more I realize how much I don't know"
chmo is offline
post #25 of 27 Old 09-10-2014, 02:03 PM
JohnyRRR
ok thanks
JohnyRRR is offline
post #26 of 27 Old 09-10-2014, 02:45 PM
joe_jeep
on my first jeep, the factory cat emptied itself into my muffler.
i put a new muffler on it. the empty cat was fine. never threw a code.
kinda sounded decent. had a welded thrush with the empty cat.
i have never heard of magnaflows failing?
seems to be the go to brand of hi flow cat.
the price is decent also. is there a better one out there?
glfwda #6624
joe_jeep is offline
post #27 of 27 Old 09-10-2014, 03:06 PM
willis36
willis36's Avatar
YOur right seems to be the go to cat. Don't know what was up with the two
that I have had. There are other brands out there, but they cost quite a bit more money. Don't know if it makes a difference, but I did not get the tj bolt on cat, but the universal weld on unit.
willis36 is offline
tj , wrangler , catalytic , converter , o2 , sensor , bypass , simulator
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
O2 Simulator for 2.5L Wranglers RoKnAzn TJ Wrangler Technical Forum 17 06-28-2006 01:27 PM
