O2 Codes P0031/P0037/P0051/P0057 - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > O2 Codes P0031/P0037/P0051/P0057
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!Poison Spyder DeFenders™ - "Tubeless" Jeep Fende
Unread 02-25-2012, 09:01 PM   #61
98xjroks
Update* I replaced the bosch sensor for the ntk/ngk sensor and the P0152 code hasn't been back within 150 miles so far so good.
98xjroks is offline   Reply With Quote
Unread 06-10-2012, 10:18 AM   #62
jpross
Btw, i know this is an old post, but after having my pcm and spark plugs replaced, i was still getting codes...i bugged the dealer and told him that i suspected the cat closest to the manifold. They tested it and said sure enough and replaced it for free under the 8/80 warranty. Everything has been working great since then...i also noticed a significant power increase... Which is awesome!
So it turned out for me the problem was a combination of three things possibly interrelated... Pcm, spark plugs, cat. Theoretically it is possible the pcm killed the spark plugs and the cat.
Hope this help anyone else with these issues.
jpross is offline   Reply With Quote
Unread 06-10-2012, 01:53 PM   #63
_KONG_
Problem fixed! Ended up being a bad PCM. Ordered a rebuilt one online and all is well
_KONG_ is offline   Reply With Quote
