nv3550 synchronizer bad, replacement questions - JeepForum.com
post #1 of 7 Old 10-20-2013, 11:39 PM Thread Starter
472cid
I ran my jeep wheeling after slave cylinder failed. It destroyed the blocking ring on 2nd gear synchronizer. How hard is it to change just that and what specialty tools would it take?
1997 Jeep Wrangler 5.0 ho gt40p motor w/ e303 cam, ax15 trans. 241j rock trac transfer case from 05 rubicon. 05 front rubicon 44 with yukon chromoly shafts and rear rubicon dana 44 and rubicon rims with 33x11.50x16 mtrs
472cid is offline
post #2 of 7 Old 10-21-2013, 07:55 PM Thread Starter
472cid
No one ???
472cid is offline
post #3 of 7 Old 10-21-2013, 08:56 PM
JeepnBlake
I would help you, but I'm not sure quite what to tell you. Your profile says ax-15, but you're asking about the 3550? I can tell you that it's not hard to fix the ax-15s, open them up, and go to town. Get a rebuild kit and take your time.
Never opened up an NV3550, but I imagine it can't be terribly different, IIRC more special tools are required.
-Blake-
Build Thread:
Dad's Build Thread:
OEM Fog Light Connectors, Conversions, and Extension Info:
JeepnBlake is offline
post #4 of 7 Old 05-04-2014, 11:10 PM Thread Starter
472cid
Little late reply but I fixed signature. Had ax15 but went to 3550 now.
472cid is offline
post #5 of 7 Old 05-04-2014, 11:12 PM
sjones26573
Profile is right. Sig is still wrong.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #6 of 7 Old 05-04-2014, 11:42 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Easy to go back to the AX 15, did that in my 04 Rubicon. Eventually will rebuild the NV3550, but awaiting parts, and time to do this. Since I have 3 AX 15 I just rebuilt, it may be a while before I need the 3550, if ever.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #7 of 7 Old 05-04-2014, 11:47 PM
LukeADukes
Download a factory service manual from jeeps unlimited
Always look both ways before crossing the stream.
LukeADukes is offline
