Nutsert for Transfer Case Removal and Install - Page 9 - JeepForum.com
 2Likes
post #121 of 563 Old 03-10-2009, 07:03 PM
Dogman
Dogman's Avatar
What happened to the images in this thread?
John 3:17
Dogman is offline
post #122 of 563 Old 03-12-2009, 12:28 PM Thread Starter
BDuece
BDuece's Avatar
Pictures have been reposted.
Bill,
BDuece is offline
post #123 of 563 Old 03-12-2009, 01:43 PM
Tim70
Tim70's Avatar
WIsh we had a subscribe feature, so my post will be it.
Marcy: '01 SE Blue 5 speed 4 banger 2" Rusty's spring lift MOABs w/265/75/r16, Warn 9000i
Tim70 is offline
post #124 of 563 Old 03-12-2009, 03:19 PM
Dogman
Dogman's Avatar
We do......click the thread tools link above.
John 3:17
Dogman is offline
post #125 of 563 Old 03-12-2009, 04:39 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
The setting you need is in your User CP page somewhere it's called the "Default Thread Subsription" or something like that and you'll need to choose an option from the dropdown box...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #126 of 563 Old 04-10-2009, 07:08 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
anyone know the length of the stock bolts? I understand 03+ are 12mmx1.75, but whats the overall length?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #127 of 563 Old 04-10-2009, 07:12 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Since it's a countersunk hex head bolt, where do you want the length measured from?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #128 of 563 Old 04-10-2009, 07:17 PM
Unlimited04
total length, head to tip.
made a 1" t-case drop out of 6061T6 and need 1" longer than stock class 10.9's.
Useful Write-Ups:
Funny:
post #129 of 563 Old 04-10-2009, 08:05 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Overall length is 50,0mm and the length from the top of the countersink to the end of the bolt is 40,0mm.
I am Savvy
mrblaine is offline
post #130 of 563 Old 04-10-2009, 08:11 PM
Unlimited04
awesome, thank you mrblaine
Useful Write-Ups:
Funny:
post #131 of 563 Old 04-18-2009, 10:59 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
I've received many emails about this thread and thought it could use a comparison photo that shows the difference between the commonly available generic nutsert and the OEM version.
I am Savvy
mrblaine is offline
post #132 of 563 Old 04-20-2009, 08:02 AM
BOTLFED98
the generic ones worked fine for me
BOTLFED98 is offline
post #133 of 563 Old 04-20-2009, 08:15 AM
NotURMailman
NotURMailman's Avatar
I feel an overwhelming desire to put my two cents worth in here... I HATE NUTSERTS! Why couldnt Jeep just use a weldnut or thicken that are of the frame and drill and tap it or, or, or, or... anyhting else!!!!!! :
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is online now
post #134 of 563 Old 04-20-2009, 09:57 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Not picking on you, but I'd like you to envision things from a manufacturing standpoint. You need a cost effective durable method to put threads in a rectangular tube that you only have single side access on.
A weld nut only works if you can get to the backside and apply pressure to hold it in place to resistance weld it. If you look at the front frame horns, there are weld nuts in there and you can see why. Full access to clamp and weld.
So, to satisfy your requirements, how would you do it? It is not even remotely feasible to thicken the frame and thread it, but if you could, imagine the threads where that part rusted the bolt in place and then the bolt broke off.
I realize that nutserts bother folks, but they are a god send from a manufacturing standpoint. Cost effective, very durable, replaceable if need be, and very effective from a strength perspective.
Before you pick on the durability, the fact that they rust together and fail is not the fault of the nut sert. It's the location that's the problem. Any threaded hole there will suffer the same fate.
I am Savvy
mrblaine is offline
post #135 of 563 Old 04-26-2009, 09:21 PM
George Dickel
George Dickel's Avatar
OEMs
I got my local dealer to price match an online dealer and got the OEMs for $6. I figured that was a good deal since he eats the shipping. While the instructions by the OP are excellent, they don't mention what a giant PITA this task is! I will add a couple details to his:
1. After grinding the tack welds and drilling the 9/16 holes, remove the heads with the chisel. It just shears off.
2. In order for the nutsert to get some traction when you are trying to get it started, press it against the frame rail at a slight angle. Only do this long enough to get it started.
Again, this project sucked but is now done and I feel good about the skid plate installation. Thanks again to the OP for this info
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip:
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline
nutsert , nutsert install
transfer case switch removal kefurd06 YJ Wrangler Technical Forum 5 05-23-2007 02:01 PM
Transfer case removal question. theonecsf YJ Wrangler Technical Forum 20 05-08-2007 06:45 PM
transfer case removal.... mmasuperman12 YJ Wrangler Technical Forum 4 01-20-2007 05:15 PM
Transfer Case Removal / SYE Install rdiller TJ Wrangler Technical Forum 22 04-14-2006 10:58 AM
Transfer Case Removal biohazardbill YJ Wrangler Technical Forum 6 08-09-2003 07:21 PM
