Nutsert for Transfer Case Removal and Install - Page 8 - JeepForum.com
 2Likes
post #106 of 563 Old 11-13-2008, 04:20 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by will228 View Post
doesnt matter. get whatever nutcerts they have. you have to drill the holes out anyway. if the certs they give u require a different bolt size just go buy em at the hardware store.
The holes in the frame for either metric or inch nutserts is the same size.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #107 of 563 Old 11-28-2008, 10:37 AM
rideraa
Good thread ... anyone considered stainless bolts . they would not rust.
Long bolt method,
As for crushing the frame, could you use a large washer or square piece of steel to help move the force out to the vertical sides of the tube.
rideraa is offline
post #108 of 563 Old 11-28-2008, 09:12 PM
dbbd1
dbbd1's Avatar
Long bolt method,
Can you get grade 5 (or metric equiv.) in stainless? Pretty spendy I bet.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #109 of 563 Old 12-01-2008, 12:29 PM
rideraa
FYI
Grade 2, 1/4-3/4 dia. 74,000 Tensile
Grade 5, 1/4-1 dia. 120,000 Tensile
Grade 8, 1/4 -1 1/2 dia. 150,000 Tensile
18-8 Stainless 1/4-5/8 dia. 100,000 to 125,000 tensile
Commonally as bolt dia. increase tensile value goes down
Today from local hardware I purchased 5/16-18 x 1 1/4 " 18-8 stainless $.50 ea (I used them on the steps)
rideraa is offline
post #110 of 563 Old 02-01-2009, 04:16 PM
JK_Unlimited
question ...
if it takes 75-100 ft/lbs to get the nutsert to collapse, and they are supposed to be torqued at 55 ft/lbs, are you risking tearing them up during collapsing them ?
reason I ask is this, one of mine got stripped out. I wasn't paying attention and the torque wrench was at 75 instead of 55.
Are the factory ones collapsed ? Or only welded in ?
JK_Unlimited is offline
post #111 of 563 Old 02-01-2009, 06:40 PM
rocknjeep
1987 YJ Wrangler
Yea if we could get a part number for the YJ certs (87) I'd flip. I have to do this to mine. My stuff seems like its in some pretty bad shape.
rocknjeep is offline
post #112 of 563 Old 02-18-2009, 05:45 PM
BOTLFED98
Originally Posted by Vacant Stare View Post
excellent info
McMaster-Carr carries nut inserts in many sizes/materials. They're cheaper than the jeep dealer (imagine that!). From the main page, look under 'Fastening and Sealing' for 'Rivet Nuts'.
I do have a question, though...were the inserts you got from Jeep steel? Did it require an ungodly amount of force to install them? I was thinking about getting some 3/8" steel nut inserts, but I wondered if I could realistically install them with hand tools.
thanks for the tip!
BOTLFED98 is offline
post #113 of 563 Old 02-18-2009, 07:13 PM
BOTLFED98
Originally Posted by mrunnell View Post
Nutserts are nutserts - just the same as any other specified fastener. They are nothing unique to Jeep. They installed easily for my and are torqued to 100ftlbs and waiting to be tacked just to make sure.
MRUNNELL, what do i order from fastenal? have a p/n?
post #114 of 563 Old 02-18-2009, 07:15 PM
BOTLFED98
Originally Posted by jeeptj19992001 View Post
think you can also get them from fastenall
what would i order from fastenal?
post #115 of 563 Old 02-18-2009, 08:05 PM
BOTLFED98
Originally Posted by scotch740 View Post
Stumbled upon this some how and I think you can find those nutserts cheaper on McMaster.com, which would be a first.
You just need to know the thickness of the frame.
If its less than 5.1mm use this number 95105A208 $10.67 for 10
If it is between 5.1 and 8.9 use this number 95105A209 $11.64 for 10
Not sure if these are the same as what you get from the dealership but maybe someone can check it out.
They also have them for 1/2" for older TJs
anyone try these from mcmaster?
post #116 of 563 Old 02-19-2009, 06:52 AM
dbbd1
dbbd1's Avatar
No, I just got mine (special order) from the dealer.
-John Wayne
dbbd1 is offline
post #117 of 563 Old 02-19-2009, 07:04 AM
JeeperAbe
how much are you guys getting these from the dealers?
1997 Jeep Wrangler SE 2.5l 4 cylinder auto, Stock.
Mods to come: 2" Coil lift, 31 MTs, Bumpers, Lights, Skids
JeeperAbe is offline
post #118 of 563 Old 02-19-2009, 07:09 AM
dbbd1
dbbd1's Avatar
Almost $10 a pop!
-John Wayne
dbbd1 is offline
post #119 of 563 Old 03-10-2009, 01:17 PM
firejeeper
bump, bump!!
00 TJ 2.5L recently to 4.56, no lockers :( 2" budget boost
Warn front bumper, JKS discos, Fire extinguisher, high lift jack and 12 ga Remington 870 (for the squirrels)
firejeeper is offline
post #120 of 563 Old 03-10-2009, 01:18 PM
firejeeper
help
Anyone in indy want to help me with this? I will supply the beer!!
nutsert , nutsert install
transfer case switch removal kefurd06 YJ Wrangler Technical Forum 5 05-23-2007 02:01 PM
Transfer case removal question. theonecsf YJ Wrangler Technical Forum 20 05-08-2007 06:45 PM
transfer case removal.... mmasuperman12 YJ Wrangler Technical Forum 4 01-20-2007 05:15 PM
Transfer Case Removal / SYE Install rdiller TJ Wrangler Technical Forum 22 04-14-2006 10:58 AM
Transfer Case Removal biohazardbill YJ Wrangler Technical Forum 6 08-09-2003 07:21 PM
