#91 | |
Well Sprung
I just found these on McMaster, they look very similar to the OE nutserts...
![]() [IMG]file:///C:/DOCUME%7E1/s_lucent/LOCALS%7E1/Temp/moz-screenshot-15.jpg[/IMG][IMG]file:///C:/DOCUME%7E1/s_lucent/LOCALS%7E1/Temp/moz-screenshot-16.jpg[/IMG]
98 TJ Sport, 4" Rough Country Lift, homemade discos, 35" BFG Mud Terrain TA KM's, 4.56 gears, Detroit Truetrac up front, factory Trac-Lok out back,Warn M8274 8000lb winch, York OBA, rock guards, custom intake, 48" HI Lift. |
#92 |
Well Sprung
Oops, let me try that again
#93 |
Well Sprung
They call these "weld nuts"... they don't crush and expand like the rivet nuts do... you just weld them in. I think this is more like what came in my 98 from the factory.
#94 |
OffTopic not transfer case related but: Does anyone know the nutserts and screws id need to install a set of rubicon rocker guards on my 97 TJ?
And do you need a tool to install nutserts? Like im completely lost on this stuff Thanks,
(O|||||||O) l_l*-----*l_l 1997 JEEP TJ
--- 2.5L | 5SPD | 30" Yokohama Geolandar M/T+ | 15" Alloy Ecco Wheels | Rubicon Rocker Guards --- My Progress Page |
#95 |
just to add to this already greatly informative thread, the part number for the bolts is 6507904aa. This is for the newer model 12mm bolts 06 and up.
The dealer I went to had no idea what I was talking about, and I had to walk him through the computer to get the right thing. Then, after placing the order he hemmed and hawed saying if they were the wrong thing I was stuck with them since it was a special order. I think his biggest issue was I had a 98 but was looking for an 06 and up part. Either way, that may help some of you when ordering. |
#96 | ||
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it." Adam Cooper (19th century) Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php |
#97 |
Drilling through the frame isn't a good idea. Besides the metal fatigue your putting clamping pressure on the frame. This isn't a good idea unless you installed a sleeve inside the frame to prevent crushing. Are you going to have a problem? Probable not! But there is a possibility.
#98 | |
Definition of Rubicon: A limit that when passed or exceeded permits of no return and typically results in irrevocable commitment. |
#99 |
Well Sprung
I'm not worried about crushing the frame. I used lock nuts, so I wouldn't have to use a ton of clamping force to keep them tight.
#100 | |
Same here!! I use new nylok nuts every time I re-install it and only tighten it enough to keep everything secure. If it was C channel I'd be leery to do this, but solid tubing I have zero worries. Thanks for the concern
97 TJ 4.0, AX15, Back halfing w/ tons and 4?s Stop by and check us out Western Mass 4x4 or Check us out on Facebook and be sure to stop by and like the NEA4WDC while your there. |
#101 |
I used a different method when I had this problem. I ground off the heads of the bolts, then dropped the skid. Then I used a heavy ballpeen hammer and just hammered the studs that were exposed back up into the frame. At this point, you can either leave them loose in your frame or if you are like me Absolutely Neurotic About Life, then you can fish them out with a piece of wire. This just leaves the face of the nutsert attached at the frame. This I just crushed with channel locks until I could pull it out of the hole. Now, the disclaimer- my frame is in great shape and no rust, so I felt comfortable doing this, knowing I would not damage the frame. Just my .02.
#102 | |
Vendor
Matt Walton http://undercoverfab.com http://blog.undercoverfab.com sales@undercoverfab.com (334) 797-7113 Check us out on Facebook
#103 |
One of mine is stripped inside. Any further progress?
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7 |
#104 |
I read all these pages with intertest, as I also have need to fix the skid/frame.
BUT... I have a Yj. Is the Yj nutsert the same as an older(pre '06) Tj? (1/2 inch x13) My Jeep stealership is no help at all and tell me those parts are not available, unless I give him a part number. But the part number is not cross-referenced by size or year. and are only special order($12.50 each) and can not be returned if wrong. So...Is this correct? part number 6035739 is the number for pre'06 Tj's? And is sea 1/2x13? And the Yj? part number 6506 629AA is for '06 -newer? and is metric 12mmx13? What information does anyone have for a Yj? |
#105 |
doesnt matter. get whatever nutcerts they have. you have to drill the holes out anyway. if the certs they give u require a different bolt size just go buy em at the hardware store.
| Tags |
| nutsert, nutsert install |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
