Nutsert for Transfer Case Removal and Install - Page 36 - JeepForum.com
 2Likes
post #526 of 555 Old 04-07-2014, 08:36 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by rustbuilder View Post
I don't know about the rest of the country,But in Oklahoma and texas they are sending the wrong nutrivets out from the dallas pdc,And I cant find the correct ones. They are sending ones that are 11/16 and doesn't even fit in the frame. Fastenal told me no luck on one to fit 5/8s hole.
I ordered a pair of nutserts, one of each for the early and late skids about 7 years ago, they were in the wrong bags and both had the wrong part number. Confused the crap out of me for a long time.
We got some more stock in, we've got about 8000 or so on hand.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
post #527 of 555 Old 03-05-2015, 05:03 PM
dereklum
Apologies for the old thread bump, but I'm going to be doing this tomorrow and I wanted to know if the original nutserts will fall down to the floor or if they're going to have to be hammered up into the frame after grinding down the welds. I saw a YouTube video of a guy doing it and after grinding off the welds, he said he had to hammer the threaded portion into the frame rail and fish them out with a magnet. Not sure if it makes a difference, but this video was on a YJ.
dereklum is offline
post #528 of 555 Old 03-05-2015, 05:46 PM
PA_LJ
Yes they will likely fall inside the frame and you will have to fish them out if you really want them removed.
PA_LJ is offline
post #529 of 555 Old 03-26-2015, 07:40 PM
tjames987
what about skipping the nutserts and just drill up through the frame [bottom and top] and insert a long bolt and nut/washer on top??? Much faster fix than the nut serts.
any thoughts?
tjames987 is offline
post #530 of 555 Old 03-26-2015, 08:28 PM
biffgnar
biffgnar's Avatar
any thoughts?
Through bolting box frame bad idea!
Romney in 2020!
biffgnar is offline
post #531 of 555 Old 03-26-2015, 09:06 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
any thoughts?
The only big concern is you are depending on the relatively thin .150 ish wall thickness to not compress when you tighten the bolts and then keep them tight.
It would be relatively easy to make a nice washer for the top that would prevent that though. Something about 3/16" thick like some of the currently available weld washers should do the trick quite nicely.
The bottom will be fine due to the skid spanning the width with another layer of steel so not much concern there. You'll need bolts about 5-5 1/2" long depending on if you keep the lower countersunk washers on the pre-03 versions.
The single biggest challenge will be drilling up through the bottom and making the hole where you want in the top. I've done similar but I had the tub off and just laid out and drilled the top hole.
Oh, it won't be a faster fix. I can have the 6 nutserts ground off and back in place fully set in about 30 minutes or less.
I am Savvy
post #532 of 555 Old 03-27-2015, 07:07 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
I broke down and got a tool for under $40 on Amazon and the nutcerts are less than a buck a pop from Fastenal. I'm finding more and more uses for this. Mine does M6 - M12, and I can get the SAE mandrels to do comparable sizes. M8's work like butter. I can't wait to try it with some M10's.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #533 of 555 Old 03-27-2015, 07:47 AM
ravenworks
Link?
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #534 of 555 Old 03-27-2015, 07:54 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Originally Posted by ravenworks View Post
Link?
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
dagr8tim is offline
post #535 of 555 Old 03-27-2015, 08:18 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Can you get a 1/2-13 nosepiece and mandrel for it? If so, do you think it has enough grunt to set the heavy nutserts in the frame?
If you're willing, I'll certainly be glad to send you some of the ones for the frame and belly skid to test for us. I'd love to be able to offer a link to a tool that works and doesn't cost a fortune.
I am Savvy
post #536 of 555 Old 03-27-2015, 09:01 AM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Half inch is 12.7mm. The tool is all steel and rated for 12mm.
I contacted the company to see about the nose pieces. I also found they carry this.
http://www.amazon.com/Astro-Pneumati...et+Nut+Kit+SAE
EDIT:
If I was going to be doing a ton of these, I'd probably break down and get this and source the noses elsewhere. They appear to be pretty standard between brands.
http://www.amazon.com/gp/product/B00...2968667&sr=8-1
dagr8tim is offline
post #537 of 555 Old 03-27-2015, 04:39 PM
ravenworks
Last year I tracked down the company that makes the Hydraulic crimper for Greenlee because I needed some dies replaced that were broken.
Long story short I bought a whole new crimper for less than half of what Greenlee was getting for them.
Blaine,is your set made in the states?
Most of my tools are made here,or so I thought.
Semper-Fi "81-84"
I.U.O.E. - 18
post #538 of 555 Old 03-27-2015, 04:42 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
EDIT:
Yes, I know what size 1/2" is in the metric equivalent, that is only part of the story. The style of nutserts you show collapsed takes about 1/3 the setting force of the heavy duty versions in the frame for the belly skid.
I also have several versions of nutsert setting tools including the long handled version you linked and I'd not like to be trying to set anything larger than the 3/8" nutserts in the style you show with any of them.
That is why I'd send you some for testing to see if you can set them. I don't see what will make that short handle tool capable, but if you tell me it will after trying some, then I'm all for pointing folks to them but only if it can be made to work.
I've been looking for a tool for several years and to date haven't found much that was acceptable for a heavy 1/2-13 nutserts that was even remotely affordable.
As far as the nose piece and mandrels being interchangeable, I've not found that to be the case either. I have 4 different tools, four different thread and nose piece configurations. I've also got mandrels without tools and tools without mandrels.
I am Savvy
post #539 of 555 Old 03-27-2015, 04:43 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
My set of what?
I am Savvy
post #540 of 555 Old 03-27-2015, 05:00 PM
ravenworks
My set of what?
Your nutsert tool,who is it made by?
Semper-Fi "81-84"
I.U.O.E. - 18
nutsert , nutsert install
transfer case switch removal kefurd06 YJ Wrangler Technical Forum 5 05-23-2007 02:01 PM
Transfer case removal question. theonecsf YJ Wrangler Technical Forum 20 05-08-2007 06:45 PM
transfer case removal.... mmasuperman12 YJ Wrangler Technical Forum 4 01-20-2007 05:15 PM
Transfer Case Removal / SYE Install rdiller TJ Wrangler Technical Forum 22 04-14-2006 10:58 AM
Transfer Case Removal biohazardbill YJ Wrangler Technical Forum 6 08-09-2003 07:21 PM
