Quantcast Nutsert for Transfer Case Removal and Install - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Nutsert for Transfer Case Removal and Install
Old 03-22-2007, 09:11 AM   #16
BDuece
Originally Posted by JeeperAbe
i dont really understand how the nutsert works and how u keep it from spinning when the new one is installed...i also dont understand how the new one is installed..i got myself all confused.
The nut and the star lock washer prevent the nutsert from spinning. You hold the wrench steady and tighten the bolt. The wrench and nut stay stationary. As you tighten the bolt it creates force on the nut and the lock washer. That force allows the lock washer to dig into the nutsert, holding it stationary. By holding the nut steady it holds the nutsert steady. The nut, lock washer and nutsert act as one moving part and the bolt is the other. The two upper washers work sort of like a bearing between the two seperate parts of the tool.
The nutsert works like this, As you tighten the bolt it forces the nutsert to collapse and expand onto the inside of the frame. Once it is collapsed it looks just like a rivet . The middle of the nutsert is bulged, making it bigger than the hole it went through.
I hope this clears it up for you.
Bill,
http://www.thisisforthesoldiers.org
BDuece is offline   Reply With Quote
Old 03-25-2007, 10:42 AM   #17
robncar
Originally Posted by BDuece
Your local jeep dealer! They cost $7.50 a piece! six nutserts and six bolts was $74.
Could you post the part number, please? If it's still handy, that is...
robncar is offline   Reply With Quote
Old 03-31-2007, 03:54 PM   #18
commodog
commodog's Avatar
bump for part number please, i just lost one on my tc skid
part # for the crossmember rivnuts (nutserts) is 6506629AA. correct?
commodog is offline   Reply With Quote
Old 03-31-2007, 05:12 PM   #19
BDuece
I went to the dealer, he pulled up an exploded view of the chassis and I pointed to the part. I don't have the part #.
Bill,
Old 03-31-2007, 06:57 PM   #20
95BadBoy
BDuece
Great how to & good pics. The way a tutorial should be.
2 BIG . Nice to give props to your
phone helper too !
If the TJ forum starts a sticky for good common tech how to's,
Mod's put this one on there.
95BadBoy is offline   Reply With Quote
Old 04-01-2007, 09:22 AM   #21
commodog
commodog's Avatar
can someone verify part number?
Old 04-01-2007, 10:02 AM   #22
Ivan
My '06 Parts List does show that part number for the nut inserts (rivets) for the "Skid Plate Support"
6506 629AA Rivet
[center]One of the 1,993 [COLOR="Yellow"]Golden Eagles [/COLOR]produced in 2006.[/center]
[CENTER][URL="http://www.jeepforum.com/forum/showthread.php?t=32021"][COLOR="Blue"]Blue Jeep Club Member #228[/color][/URL][/CENTER]
Ivan is offline   Reply With Quote
Old 04-01-2007, 11:17 AM   #23
robncar
6506 629AA Rivet
Yep, for the late models, they are 12mm metric. The early models were standard, 1/2" I think. It's the early part # that we need too...
Old 04-01-2007, 06:57 PM   #24
commodog
commodog's Avatar
I'm gonna cal the jeep stealership tomorrow, and or might go buy a welder and just tack the damn thing back in place
Old 04-02-2007, 08:16 AM   #25
commodog
commodog's Avatar
my local dealership can't find the part number for a 99 sport.... wtf?
Old 04-02-2007, 08:52 AM   #26
commodog
commodog's Avatar
ok, got a part number from a dealer in another town,
All it said for 99 TJ was - skid plate nut - #6035739
quantity used 6 - $7.50 a piece
Can someone verify this?
Old 04-02-2007, 02:12 PM   #27
commodog
commodog's Avatar
Dealership told me all they could do is cut open the frame and weld a new nut in there.
They said it wasn't a very common problem for these to come loose.
wow
I'm going to make this tool and try it out and see if i can save the one that is still in there.
Old 04-02-2007, 02:34 PM   #28
robncar
AWESOME!!! I think this is it. I have the factory parts printout. This part is NOT shown on the illustration but is listed. It says just what you said "06035739, 6 required, NUT Skid Plate". This must be the early model 1/2" nutsert!
Thank you!!!
Old 04-02-2007, 04:17 PM   #29
BDuece
Thats what I paid for them. Even worse I paid $4.20 each for the factory bolts and I ended up not using them. You don't have to buy all 6!
Bill,
Old 04-02-2007, 07:55 PM   #30
commodog
commodog's Avatar
well attempt at resurrecting spinning nutzert failed miserably.
Bolt comes out easily but will not tighten.
I just lock tighted the heck out of it and the other 5 tight bolts and will call it good till I get back from my trip to colorado.
I'm leaving next weekend and driving, so I'll just keep a socket handy and check them every morning.
I'm going to go ahead and order 3 from the dealer and fix it when i get back.
nutsert, nutsert install
Glock Forum
