#181 | |
That's why I tack welded mine as well. But my original 10 y/o nutserts broke at the crush point. That's why I needed to replace them.
#182 |
Deleted! Deleted! Deleted! Deleted! Deleted! Deleted! Deleted! Deleted! Deleted! Deleted! Deleted! Deleted! Deleted! Deleted!
Still Burnin Oil since 1992! GDE ECO Tuned 2006 CRD Sport Black, B&G Trans drain kit, Front and rear hooks, Full Skids GDE HOT Tuned 2006 CRD LTD Silver, B&G Trans drain kit GDE TCM tune 2010 MB 2500 Sprinter Van 2005 MB 2500 Sprinter Van Last edited by flman; 10-06-2009 at 05:51 AM.. Reason: Posted wrong forum |
#183 | |
6035739 is the part # for 97-02 1/2 Standard version 6506629AA is for 03-06 M12 metric version. The website has both of those listed as well. I don't see a picture for the part # you have listed. http://moparonlineparts.com/search.htm Last edited by BDuece; 10-05-2009 at 12:17 PM.. |
#184 |
Still Burnin Oil since 1992! GDE ECO Tuned 2006 CRD Sport Black, B&G Trans drain kit, Front and rear hooks, Full Skids GDE HOT Tuned 2006 CRD LTD Silver, B&G Trans drain kit GDE TCM tune 2010 MB 2500 Sprinter Van 2005 MB 2500 Sprinter Van Last edited by flman; 10-06-2009 at 05:51 AM.. Reason: posted wrong forum |
#185 |
#186 | |
Still Burnin Oil since 1992! GDE ECO Tuned 2006 CRD Sport Black, B&G Trans drain kit, Front and rear hooks, Full Skids GDE HOT Tuned 2006 CRD LTD Silver, B&G Trans drain kit GDE TCM tune 2010 MB 2500 Sprinter Van 2005 MB 2500 Sprinter Van Last edited by flman; 10-11-2009 at 12:44 PM.. |
#187 |
Is the '97-'02 nutsert #6035739 the same as the one for '87-'93 YJ's?
#188 |
It couldn't hurt to try one!
#189 |
The price has gone up @ the dealerships. My girlfriend just had to order 6 for her jeep and they were $9.20ea.
EVERY dealer quoted that price.... Just a heads up ![]() |
#190 |
Yup, that is about what I paid from the dealer as well.
The opinions of worthless people, are worthless. The only problem that you have with anyone in this world, is what you expect of them. Society is no match for a stupid person. "Life Is tough but it is tougher when you are stupid" -John Wayne |
#191 |
Just wanted to say thanks to the OP and mrblaine for the nutsert tool idea. I made one for metric nutserts as follows:
1x M12x55mm bolt 1x 5/8 star washer 1x 14mm hex nut (no drilling required) 2x M12 flat washers I used it to replace three nutserts and had zero problems. Thanks again. |
#192 |
BUUMP
i called the jeep dealer service dept to get the correct sizing of bolt for the t case skid yesterday so i could do my transfer case drop..the guy gives me the size. I buy them and install them. I called him back and said that something was up and that they went in hard..he says "oh i gave you the standard size for the 97-02 not the metric for the 03-06 wranglers) so pretty much i cross threaded all my nutserts in my frame because of someones screw up now i have to get all of em replaced Idk what to do. How expensive is replacing these or having the non spinning ones replaced at shop rates? I can't do it myself.
SUPPORT THE TROOPS 2006 Jeep Wrangler|BDS|BFGoodrich|Uniden|Upol|HiLift|Cragar| Hella|Alpine|JKS|PoisonSpyder|Delta|Aussie Locker|Bluetorch Fab|Novak|Trail Gear -Zach
#193 | |
First thing I'd do is get new nutserts of the correct type. Then buy new bolts and test every bolt and nutsert and make sure they thread easily. The bolts only thread in a little bit, but you can tell very quickly if they're the right size or not. Then I'd try seeing which bolts can be unscrewed. If you can get a few out, you might get enough play in the skid to get a prybar between it and the frame rail which will allow you to pry downpressure on the skid against the stuck bolt heads. This can possibly get enough purchase on the spinning ones for you to unscrew them. I got two of three out this way. The last one was stubborn and I had to borrow an air chisel to cut the bolt head off so I could drill it out. I bought a pack of new chisels for the guy in exchange for the loan. Don't give up, you may be able to save yourself a few bucks. |
#194 | |
Raising this from the dead ...
I called the service department to get the nutserts and they told me the nutserts were $10 a piece and there wasn't a part number, he said they were just called transfer case frame nuts.. fair enough. But I also went to mopar online parts and put in the part # 6035739 and it comes up with this 6035739 $9.10 $0.00 $6.00 NUT NONE That make sense to anyone ? they dont offer a picture or anything so I can't be sure if I'm ordering the right parts.. Can anyone shed some light for me, or even if anyone has an extra set of 6 1/2" standard inserts, I'll just buy them from you knowing they're the correct ones. Thanks guys
"Run what ya brung and hope ya done brung enough" Quote:
#195 |
That is the correct part #. It all depends on where you go. Some guys get it some don't. If you need them I would order them from that site.
| Tags |
| nutsert, nutsert install |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
