Nutsert for Transfer Case Removal and Install - Page 12 - JeepForum.com
 1Likes
post #166 of 555 Old 09-23-2009, 09:09 PM
ldso
welder
I had to grind off a few bolts on my YJ, and somebody had already rigged up a couple of studs (instead of bolts), but their fix didn't work. They all were rusted up and just spun in the frame. I tried the drilling a small hole and saturating with PB, and also prying and using the weight of the transfer case to push down on the bolt.
I ended up with a transfer case drop installed (from my Rough Country lift) but with only 2 bolts instead of 6 holding it together. Scary. It hung on enough for me to drive it to the welding shop across town. They are welding nuts onto plates, and welding the plates onto the frame. That should be a permananent solution that will let me unbolt the transfer case for maintenance easily, and an improvement over the original design.
Thanks for driving me home from the welding shop sweetie
1995 YJ "Mabel", 2.5L Muncie SM465 np231j 4.88's HP30 Lockright JK 44 Detroit 33s CJ clip
Actually, it's pronounced "mill-e-wah-que" which is Algonquin for "the good land."
ldso is offline
post #167 of 555 Old 09-29-2009, 04:57 PM
rollerized
Went to 2 Jeep dealers to get the nut inserts and bolts, but they could not find them. Anyone know where I could get these?
rollerized is offline
post #168 of 555 Old 09-29-2009, 06:30 PM
dbbd1
dbbd1's Avatar
How many do you need? I have a few extras (my dealer did have them).
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #169 of 555 Old 09-29-2009, 06:52 PM
4.0l sahara
just went and ordered them at my dealer yesterday. I got them today took 1 day.
4.0l sahara is offline
post #170 of 555 Old 09-29-2009, 08:42 PM
PurpleTJ
ok so i have to do this to 2 bolt / holes, and im just not sure how to do it. i read over the write up multiple times, and i think i either suck at understanding what i am reading, or i am missing something. i understand the concept of the nutsert tool, but the part i dont get is how the tool stays held into the frame. the write up says you should tack weld, or loctite it in place, but it says to do that after you install them... does that mean after you slide them into the frame? or after everything is all said and done?
so i guess what my question is, how does the tool stay held into the frame?
Purple Jeep Club member #8
PurpleTJ is offline
post #171 of 555 Old 09-29-2009, 08:46 PM
Hesher420
^Just like a rivet gun, you push on the tool to hold it, and the nutsert in the frame hole. After you crush the nutsert into place, you remove the tool. Then, after the nutsert is in and the tool is removed, tac weld it if you feel it is necesary.
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline
post #172 of 555 Old 09-29-2009, 08:48 PM
Dmcastino
The tool itself isn't held to the frame. Basically you thread the nutsert onto the little tool thing and stick it in the hole of the frame. The nutsert and tool have to be held up with the wrench that you are using on the tool. Then you just have to tighten the tool and it crushes the nutsert which makes it stay in the frame. Does that help at all?
Dmcastino is offline
post #173 of 555 Old 09-29-2009, 08:53 PM
PurpleTJ
ah! i finally get it. i said before that i understood the concept of the nutsert tool... i lied. i didnt realize that it expands (or gets 'crushed') or whatever, to hold it in place. i get it now. thanks for the help!
PurpleTJ is offline
post #174 of 555 Old 09-29-2009, 11:28 PM
sardog12
sardog12's Avatar
I recently had to replace one of mine. I got the one from the dealership based on blaine's advice and then tacked it to the frame before crushing it. After putting the other 5 bolts in place for the skid, I put the 6th in until it crushed sufficiently and it worked like a charm. I also tacked the other 5 down to hopefully prevent them from ever spinning in the future.
GEAUX TIGERS
sardog12 is offline
post #175 of 555 Old 09-30-2009, 02:18 PM
rollerized
I need 3 plus bolts
post #176 of 555 Old 09-30-2009, 07:56 PM
dbbd1
dbbd1's Avatar
I need 3 plus bolts
Well, is it 3 or more? Bolts or the nutserts?
-John Wayne
dbbd1 is offline
post #177 of 555 Old 09-30-2009, 08:15 PM
w9kh_kevin
I'm thinking he means 3 nutserts (plus) 3 bolts
'90 YJ - stock, long since sold
'97 TJ - 4 cyl, ax-5, np231, 2"bb, 31's, Vortex winch, stock axles, soft on the top-hard on the bottom.
2005X
i knew if didnt get what i could afford now i would end up blowing the money on something else
w9kh_kevin is offline
post #178 of 555 Old 09-30-2009, 09:24 PM
dbbd1
dbbd1's Avatar
Oh! Duh! Sorry.
-John Wayne
dbbd1 is offline
post #179 of 555 Old 10-01-2009, 08:06 AM Thread Starter
BDuece
BDuece's Avatar
Tack welding them doesn't necessarily mean your not going to have a problem in the future. Mine where tack welded and I still needed to replace them. The weak point of the nutsert is the area that gets crushed. If that area becomes rusted or weak from stress, it can break.
Bill,
BDuece is offline
post #180 of 555 Old 10-01-2009, 08:43 AM
sardog12
sardog12's Avatar
I realize that but hopefully it will make it at least less likely. The weakness may be the area that gets crushed but, from what I have seen, that area does not usually break off. It usually weakens and no longer applies the "squeezing" pressure on the frame, allowing it to spin. The tack weld should hopefully help against the spinning.
GEAUX TIGERS
sardog12 is offline
nutsert , nutsert install
transfer case switch removal kefurd06 YJ Wrangler Technical Forum 5 05-23-2007 03:01 PM
Transfer case removal question. theonecsf YJ Wrangler Technical Forum 20 05-08-2007 07:45 PM
transfer case removal.... mmasuperman12 YJ Wrangler Technical Forum 4 01-20-2007 06:15 PM
Transfer Case Removal / SYE Install rdiller TJ Wrangler Technical Forum 22 04-14-2006 11:58 AM
Transfer Case Removal biohazardbill YJ Wrangler Technical Forum 6 08-09-2003 08:21 PM
