Nutsert for Transfer Case Removal and Install - Page 10 - JeepForum.com
 2Likes
post #136 of 563 Old 05-22-2009, 08:15 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
would it work to put a couple little tack welds on the bottom the factory nutsert on the frame? like 2 or 3 equally spaced? would that hold enough to keep it from spinning? or is the nut actually spinning inside the sert?
i gotta drop my skid and trying to figure out how to prevent from getting into a big issue...
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #137 of 563 Old 05-22-2009, 08:24 AM
robncar
robncar's Avatar
A couple of tack welds will work great, it has for me and many others. Still, whenever I do anything with the nutserts, I chase them (gently) with a tap and silicone spray the nutserts and the bolts. The nutsert is one piece, the base and threaded portion. The only way for the threaded portion (what you're calling the "nut") to spin free of the base is if it actually breaks.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #138 of 563 Old 05-22-2009, 08:25 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Up until around 03, the factory did put a pair of tacks at the flange on the nutsert to the frame. That doesn't stop the spinning for the most part because the real issue is the threaded barrel rusts at the base and then twists off when the threads get rusted to the bolt.
If you do get one that the flange spins on, try some method to tighten the bolt and set the nutsert tighter.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #139 of 563 Old 05-22-2009, 08:29 AM
robncar
robncar's Avatar
What's rust?
robncar is offline
post #140 of 563 Old 05-22-2009, 08:56 AM
Unlimited04
I've started the PB-Blaster, so **hopefully** they'll come out no problem...but after my rear shock issue, i'm hesitant. my jeep started life in the rust belt of michigan/ohio area. i may have an M12 tap too...good idea. would it be better to remove the bolts with the air impact, or the slow method with a breaker bar?
Useful Write-Ups:
Funny:
post #141 of 563 Old 05-22-2009, 09:12 AM
Alexia
Alexia's Avatar
Apply heat to the heads of the bolts with a propane torch first.
For me, I skipped all precautions and went for the air impact first. Both side came out fine and there was plenty of rust hidden up in there. I have painted over it now.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #142 of 563 Old 05-22-2009, 10:08 AM
robncar
robncar's Avatar
What I've done before is to use a large c-clamp from the top of the frame to just next to the bolt head in an attempt to put additional upward pressure on the skid to try to clamp the nutsert head between the skid and the frame.
robncar is offline
post #143 of 563 Old 05-28-2009, 09:16 PM
Mini-Me26
Just throwing this out there, so forgive my ignorance, but would it be possible to just forget the nutsert technique and use a nut in the frame? Access the nut through a hole in the side of the frame by the mounting holes, the new hole would be just large enough to fit a socket, then ratchet through (or combo wrench, whatever works).
Mini-Me26 is offline
post #144 of 563 Old 05-28-2009, 10:16 PM
Jeepguy1977
Jeepguy1977's Avatar
Are these nutserts still available? I have a stripped one.
1998 TJ, 4.0L Auto and various junk
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline
post #145 of 563 Old 05-29-2009, 05:41 AM
robncar
robncar's Avatar
I don't think I'd want additional holes in the frame. I'm lucky though, now that I have the RE LA skid. The center section is removeable to service the t-case and trans. Hopefully, I'll never have to deal with those nutserts again!
robncar is offline
post #146 of 563 Old 05-29-2009, 06:43 AM
dbbd1
dbbd1's Avatar
There are other options but I got mine from the dealer.
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline
post #147 of 563 Old 05-29-2009, 06:57 AM
w9kh_kevin
This should be a sticky for general info on replacing the rivet nuts. I just dealt with them for the first time on my flares, so I understand what the issues are.
w9kh_kevin is offline
post #148 of 563 Old 05-29-2009, 07:03 AM
w9kh_kevin
Originally Posted by robncar View Post
What's rust?
I got your rust right here
I didn't know it was possible to have a vehicle without it!
post #149 of 563 Old 06-03-2009, 07:16 PM
AngusTJ
RUST SUCKS
Too bad they cant make a material as strong as steel and affordable (dont think i'd buy a carbon fiber Jeep)
"Run what ya brung and hope ya done brung enough"
Originally Posted by pjleslie03 View Post
I know how bad the D35 is in the rear, but would it be bad to have one in the front?
Originally Posted by Lostj View Post
yes, you wouldn't be able to steer
98' TJ, 4" Superlift, JKS 1.25" BL/ 1" MML, 8k Gorilla winch, Cowl intake, D30 Aussie, shafts/D44 Powertraxx, shafts (4.56's), Rusty's Adj CA's front/ RE Adj CA's rear, Recessed tails, sway discnct'd, 152 db train horns, 34x10.5 LTB's Amer Rac/36x13.5 Irok's Streetlocks, Grenade shifter, Pioneer deck/speakers, Warn bumpers, KC upper lite mts/Slim lites, EBC yellows, 40 series Flowmaster, couple tasteful more ...
AngusTJ is offline
post #150 of 563 Old 06-04-2009, 02:59 PM
Mini-Me26
Originally Posted by AngusTJ View Post
RUST SUCKS
http://www.jeepforum.com/forum/f9/new-gas-tank-skid-plate-can-you-say-aluminum-773797/
Technically it still rusts, but it's a start.
nutsert , nutsert install
transfer case switch removal kefurd06 YJ Wrangler Technical Forum 5 05-23-2007 02:01 PM
Transfer case removal question. theonecsf YJ Wrangler Technical Forum 20 05-08-2007 06:45 PM
transfer case removal.... mmasuperman12 YJ Wrangler Technical Forum 4 01-20-2007 05:15 PM
Transfer Case Removal / SYE Install rdiller TJ Wrangler Technical Forum 22 04-14-2006 10:58 AM
Transfer Case Removal biohazardbill YJ Wrangler Technical Forum 6 08-09-2003 07:21 PM
