Nth Degree/AEV Rear shock shifters - JeepForum.com
post #1 of 6 Old 08-30-2009, 09:34 PM Thread Starter
sduncan
sduncan's Avatar
Looking at getting a set of these. Anyone have them? Looking for input about them. Good/bad points? Issues after install? Do they increase/decrease(lengthen/shorten) available shock travel?
I do not want to do the whole "ford towers to the outside of the frame" bit, but would like to gain a little clearance if possible, and also need to increase shock travel a little.
Thanks
'98 TJ, 5.7 HEMI,
sduncan is offline
post #2 of 6 Old 08-30-2009, 09:37 PM
Bishop Creek
Well, check this thread out. He put AEV shock relocators on:
http://www.jeepforum.com/forum/f9/up...wesome-796470/
“This isn’t the Old West, because the New West has never arrived. It’s just the West, like Wyatt Earp died yesterday.”
─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996.
Bishop Creek is offline
post #3 of 6 Old 08-30-2009, 10:01 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
theres a few thread on here regarding these, use the search. Nth/AEV isn't the only game in town. Superlift makes a nice weld on kit, and BTF and MORE have similar DIY spring buckets too.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 6 Old 08-30-2009, 11:13 PM
mudb8
want it rite or rite now?
mudb8's Avatar
the problem with kits other than nth that aren't fully outboard is the mounts are moved up and you loose uptravel.
the shock shifters allow you to use longer shocks on smaller lifts.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #5 of 6 Old 08-30-2009, 11:26 PM Thread Starter
sduncan
sduncan's Avatar
^^^^ is my problem.
Here's the deal. In 2005 I did a Rubicon Express 4.5 longarm. I went with the RE mono tube shocks. Since my install, RE has determined that the shocks that came with the kits then were a tad too long and could bottom out slightly before the bump stops did. They have since started using a shorter shock to eliminate this.
Well, one of mine went bad, I sent it back(lifetime warrenty) and they honored the warranty. For that I appreciate their efforts(as well as one of the vendors here, i.e. Redrock 4x4). But I was told that I need to either adjust my bumpstops(meaning decrease my travel which I really don't want to do), configure my mounts to match the shock length, or buy new, shorter shocks. Since I wanted to change the mounts anyways, I chose this route. If the Nth degree mounts will give me shock travel I need, and move them outboard a little at the same time then thats what I'll do. From the above post, that seems to be the deal....
Thanks fellas,
Any further input/advice would be much appreciated as well.
'98 TJ, 5.7 HEMI,
sduncan is offline
post #6 of 6 Old 08-30-2009, 11:41 PM
mudb8
mudb8's Avatar
lower relocation alone will gain you upto 1.25".
I also make lower relocation mounts and will send free patterns to DIY'er's... the material needed are about 10 bucks, having the means and ability to weld.
stock mount...
relocated lower..
mudb8 is offline
anyone use Nth Degree Mobility Shock Shifters Rafikie TJ Wrangler Technical Forum 3 07-18-2008 05:37 PM
Shock Shifters and 8.8 TSWRA TJ Wrangler Technical Forum 6 10-18-2005 11:43 PM
bds shock shifters TSWRA TJ Wrangler Technical Forum 4 08-15-2005 03:10 PM
Doh!! Looks like it's time for some Nth° Shock Shifters wayoflife TJ Wrangler Technical Forum 6 02-14-2005 01:45 PM
