NSG370...at a loss - JeepForum.com
post #1 of 18 Old 07-08-2013, 05:35 PM Thread Starter
chevy2169
NSG370...at a loss
Just rebuilt my nsg370 this past weekend. New bearings all around, due to a squeaking noise that occured only when the clutch was out and the jeep was idling in neutral. Push the clutch in, squeak/squeal goes away. My first guess was the input shaft bearing. So I replaced all the bearings in the trans. Lots of work for no end result right now.
Keep in mind I replaced the clutch with a Luk kit a few months ago, the noise didn't start until after this. Napa warranteed the clutch, and I put a brand new Luk kit in after I rebuilt the transmission. All day yesterday I drove it with no noise, now the noise is worse.
If you depress the clutch pedal a tiny bit, the noise gets worse. All the way, it goes away. I'm telling you straight up, that there is NO way it's the input shaft bearing. The trans was rebuilt by the book with genuine Mercedes parts (which could be the problem in the first place, sarcasm). I'm under the impression though that throwout bearings only make noise when the clutch is depressed. The pilot bearing wouldn't make the noise because it's brass. I'm at a loss, and wondering where the hell to go from here. I'm not looking forward to ripping the trans out for a third time in less than 4 months.
My best guess right now is that both throwout bearings in the clutch kits were ****. I've had experiences like this before with auto parts suppliers at my work, and it sucks to have to do **** twice.
I'm thinking about biting the bullet and telling napa to give me the money back, and throwing a centerforce in. Any ideas would be appreciated.
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dip****s.
chevy2169 is offline
post #2 of 18 Old 07-08-2013, 06:17 PM
ops5
ops5's Avatar
Well, that sucks. I can't help you out, but yeah, you read in all these threads it is the input shaft bearing causing the rattle. Very interested to what you find out, because mine make the same noise.
ops5 is offline
post #3 of 18 Old 07-08-2013, 06:20 PM Thread Starter
chevy2169
It isn't the rattle. It's a squealing. I've dealt with the rattle since day one. Even with brand new mopar/mercedes bearings in it, the input shaft has play and rattles. Perks of the transmission I guess.
This thing sounds like a pig getting raped.
post #4 of 18 Old 07-08-2013, 06:33 PM
ops5
ops5's Avatar
That, I thankfully do not have
ops5 is offline
post #5 of 18 Old 07-08-2013, 07:46 PM Thread Starter
chevy2169
I'm convinced it's the throwout bearing not fully releasing off of the fingers on the pressure plate.
post #6 of 18 Old 07-08-2013, 08:05 PM
06philaTJ
There were some threads on here where a few people had some concerns with throw-out bearings with the luk clutch kits. Not sure if that is the issue but might be of some help.
This is one of them:
http://www.jeepforum.com/forum/f9/lu...34/index6.html
06philaTJ is offline
post #7 of 18 Old 07-09-2013, 05:18 AM
Dean7276
Worn shift fork pads possibly. The plastic pads wear away causing metal on metal contact. Will cause a squealing/screeching sound even in neutral. Not individually replaceable, need to buy whole shift fork assy. I would look into it, NSG370's are known to go thru these pads prematurely. Mine were shot after 55,000 miles.
Dean7276 is offline
post #8 of 18 Old 07-09-2013, 07:50 PM Thread Starter
chevy2169
It was the throwout bearing. I pulled the transmission again today. Napa had sent me the clutch kit with the crappy plastic throwout bearing in it. They warranteed the clutch again, yes again, third one, and I bought a throwout bearing from The Jeep dealer here. Worth it.
The dealer bearing is all metal, made in the USA (not Mexico), and is much more heavy duty as far as the springs and the casting are concerned. Drove the jeep about 40-50 miles today after work, no noise....yet (fingers crossed). From my experience in the automotive field, aftermarket parts are hit or miss.
I was also thinking about the shift rail assembly, but I did look at it when I was rebuilding the transmission and the pads looked decent still, so I didn't bother replacing it for no reason. Trans now shifts like butter though, and is much quieter than it used to be. I'm glad I spent the exorbitant amount of time and money.
post #9 of 18 Old 07-09-2013, 08:00 PM
ops5
ops5's Avatar
Awesome, glad you got it fixed
ops5 is offline
post #10 of 18 Old 07-09-2013, 10:33 PM
Necko2529
Necko2529's Avatar
You must have played Ænema this time around and all's well. Glad you got it fixed.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #11 of 18 Old 07-09-2013, 10:44 PM Thread Starter
chevy2169
actually I had Zeppelin II cranking in the shop tonight lol. Just a fair warning to everyone, stay the hell away from Luk clutch kits. I know it's been said before, but with this one, I'd go OEM from the dealer.
post #12 of 18 Old 07-09-2013, 11:01 PM
Necko2529
Necko2529's Avatar
I threw Sachs in after i blew my LUK in a mudhole. It's been good so far with about 35-40K. I get the normal TOB chatter that the LUK with all metal TOB was making as well.
Led Zep is one of my favorite bands, I'd have no problem helping you wrench on the Jeep.
post #13 of 18 Old 07-09-2013, 11:03 PM Thread Starter
chevy2169
post #14 of 18 Old 07-10-2013, 07:57 AM
rubidriver
Keep us updated on whether or not this was the fix and if it comes back
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #15 of 18 Old 07-10-2013, 03:55 PM Thread Starter
chevy2169
I will. So far so good.
