NP241J Rock Trac Transfer Case 4WD Switch REVEALED!! - Page 3 - JeepForum.com
 1Likes
post #31 of 69 Old 03-16-2011, 02:00 PM
yogi250cc
I too am curious if that switch would work in reverse. As in putting a 231 in place of a 241.
2006 RUBICON
with new to me dana 30 and dana 35 rear
(dont wanna talk about it)
yogi250cc is offline
post #32 of 69 Old 03-17-2011, 08:00 PM
yogi250cc
Wow!
Thought jeep forum was a wealth of information. Guess not. O well thank god for pirate4x4.com
2006 RUBICON
post #33 of 69 Old 03-17-2011, 10:02 PM
tjsean0308
WOW!!!! indeed.
tjsean0308 is offline
post #34 of 69 Old 03-26-2011, 07:32 PM
Akunin
I had two "windows" open when I ran across this thread. One was JF (obviously) and the other had the very same pigtail and switch sitting in checkout waiting to be paid for... you saved me $50! Thanks for the post!!
Akunin is offline
post #35 of 69 Old 04-04-2011, 06:02 PM
kloppk
Best price I found for the switch and pigtail plug was from Amazon.com.
Switch Dorman 600-506 $13.64
Pigtail Plug ACDelco PT724 $21.16
Works like a champ
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #36 of 69 Old 04-04-2011, 06:45 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Nice work, added to the FAQ.
It only took me 2 1/2 years to do this.
Wheelin98TJ is offline
post #37 of 69 Old 04-25-2011, 07:49 AM
zouaveherb
So my light stops working on my Ruibicon TJ and I want my diffs to lock in 4WL. I followed this thread and get a new switch--and it turns out that Rubicon 241s were built with the original switch. D'oh!
So three questions:
1. Does anyone know where to get the original switch? The part number on mine is not legible.
2. Does anyone have a original switch they don't need?
3. Does anyone need a Airtex 1s4219? I'd be willing to trade for a original switch!
zouaveherb is offline
post #38 of 69 Old 04-30-2011, 09:03 PM
5packer
I just installed the 241 into my 2004 wrangler. (swaped out the 231j) I will gladly swap switches with you.
5packer is offline
post #39 of 69 Old 05-01-2011, 11:54 PM
zouaveherb
Deal!
PM me with your address!
post #40 of 69 Old 05-04-2011, 06:08 PM
zouaveherb
Originally Posted by zouaveherb View Post
Deal!
5packer,
I haven't heard anything from you. Are you still interested in the switch swap?
post #41 of 69 Old 05-27-2011, 06:10 PM
zouaveherb
5Packer backed out of the deal. I ended up buying a switch. Does anyone want to buy my 1s4219 off of me? It's never been installed and cost me $34.43 after shipping from Rock Auto. Make me a offer! I'm tired of staring at it on my desk at work!
post #42 of 69 Old 09-29-2011, 06:01 PM
zouaveherb
Originally Posted by MattGATRTJ View Post
Does anyone have any experience with the opposite of this situation. Say I removed the 241 from my Rubicon and installed a 231, now I cannot get the 4wd light to work properly. Using an older switch from a 231 does not work at all on the 06 rubicon. If I put the 241 switch in the 231, then I can get the 4wd switch on in 2wd along with the CEL. The switch button is too long and will not let you shift the t-case. I can fix the shifting problem, but the CEL and getting the switch to function in the opposite position is not possible.
I have not found any info on this.
I know "why would you get rid of a 241?" Cause it goes great with a D30 & D35.
I know this is a old post to reply to, but I came across the answer while trying to figure out what was wrong with my Rubicon's 4wd system. So here goes:
With a Jeep shipped with a 231, the 1s4219 switch wiring directly goes to the 4wd light in a on/off fashion. So it's cosmetic for the most part.
The Rubicons are wired up differently. The 6-position (only 4 positions are monitored) switch on the 241 sends varied voltage to the PCM depending if it's in 2H, 4H, N, or 4L. This is because the PCM only wants the Rubicon to lock it's diffs in 4L while traveling less than 10 miles per hour. So if the PCU gets the 4L signal and the signal from the spedo says it's going less than 10 MPH, then the PCU will allow the lockers to lock.
So putting in a 241 into a non-Rubicon is fairly straightforward--all you need is the 1s4219 switch, assuming you care about the light going on or off.
Putting in a 231 into a jeep with a Rubicon harness is less straightforward--You will need to bypass the PCM so you can lock the diffs (see other posts for that mod) or trick it into thinking it still has a 241 in it.
post #43 of 69 Old 09-29-2011, 06:23 PM
zouaveherb
Originally Posted by rieveskp View Post
i have an 04 rubi and my 4wd indicator lights and my lockers are not working is this what i need to do
This was my exact problem.
Your options are:
1. Replace "SWITCH, Transfer Case, 5 Position" (it's really 6 positions, but I digress...) part # 5083138AA.
2. Reset your PCM. http://www.jeepforum.com/forum/f96/h...et-pcm-566770/
3. Find someone with a DRBIII tool to tell you what's wrong. Then either do option 1, option 2, or something else depending on what the DRBIII tool says.
I did option 1 then 2. I wish I'd done option 2 first.
post #44 of 69 Old 10-07-2011, 10:43 AM
TGLPilot
TGLPilot is offline
post #45 of 69 Old 02-04-2012, 07:07 AM
TURBevO8
Just ordered these parts from Amazon. With shipping it was like $66 which I thought was a little high but oh well. At any rate this is a great thread! Thanks! Now onto my speedo issue info search...
2006 Impact Orange TJ X
2004 Apex Silver EVO VIII GSR
TURBevO8 is offline
transfer case vac switch xxgunrunnerxx YJ Wrangler Technical Forum 7 12-08-2009 01:59 PM
transfer case switch? dwaynetm1 YJ Wrangler Technical Forum 3 05-19-2009 06:16 PM
NP241J 4WD Indicator Light Switch joe130 TJ Wrangler Technical Forum 1 12-17-2008 08:55 AM
rock trac rubi t-case..where to buy one? dealership only? premo JK Wrangler Technical Forum 5 11-25-2008 11:23 PM
Transfer case vaccuum case switch Hambne YJ Wrangler Technical Forum 7 07-11-2007 04:36 PM
