NP241J Rock Trac Transfer Case 4WD Switch REVEALED!! - Page 2 - JeepForum.com
 1Likes
post #16 of 69 Old 05-18-2010, 04:00 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Nice info, there have been a lot of people asking about this very subject. Good work Joe!
Jerry Bransford is online now
post #17 of 69 Old 05-18-2010, 05:08 PM
tjkj2002
2002 KJ Liberty
Advance Adapters has a kit for $50,same parts.I have this kit since my Liberty uses the same sensor.Comes complete with instructions,some resistors are needed($1 at radio shack) for use in JK's and such.
300378X | Engine & Transmission Conversion Adapters - Advance Adapters
tjkj2002 is offline
post #18 of 69 Old 05-19-2010, 11:35 PM
Bill C
Thanks for all this info...........I'll be doing the same.
Just to be sure I understand, the existing switch in my NP231 (98 TJ) is normally open (or closed) and the switch on the NP241 I have from a 04' wrangler is the opposite??? That is why the switch needs changed, not just the plug???
Thanks again for all the work.........
As an electrician I always advise:
"Remember, it's only a shock if you don't expect it" :-)
Bill C is offline
post #19 of 69 Old 05-19-2010, 11:44 PM
LuckRider
LuckRider's Avatar
That is a great writeup. If I were swapping cases, I would want the 4wd light to work. Too bad there aren't the lights for the lockers. If there were, you could get those to work for the ARBs.
I do have a question though, why is it the 241J? If you search that, there is like no info (although that is what I originally thought it was). If you go to Gear Ratio Calculator and go to select a t-case, you have the NP/NV/NVG241 or the NP241OR. There is no mention of the 241J, and the 241or is the one with 4:1 low.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #20 of 69 Old 05-20-2010, 12:43 AM
oderalxjlaredo
X2. Please explain how how the 241OR does not actually exist?
by the thing that spins when you drive underneath
oderalxjlaredo is offline
post #21 of 69 Old 05-20-2010, 12:53 AM
RogueSpear2023
To my understanding the NV241OR is what Chrysler calls the T-case from a Rubicon but when it comes to actually buying one online I believe they are only NV241J like what comes in all the JKs, the "OR" part stands for Off Road, and Chrysler added this terminology to explain he difference between the NV241J that comes in standard JKs, and the NV241 out of a Rubicon, so yes when it comes to parts online, and from new venture I don't think it really exists, but in Chrysler's world it does. So the only way to buy a NV241OR is to get one from a Rubicon, and if you get it, it will come with 4:1 low gears.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #22 of 69 Old 05-20-2010, 06:58 AM
LuckRider
LuckRider's Avatar
That makes sense. If you read the FSM for a Rubi, the lockers and t-case are referred to as the Off-Road package.
Support Our Troops!
JFI Member #7:
post #23 of 69 Old 05-20-2010, 08:20 AM
Bill C
Now that I think it through...........the existing switch on my NP231 must be normally open or the light would be on with it un-plugged.........
Bill C is offline
post #24 of 69 Old 05-21-2010, 03:48 PM
Deacon
Shining Adonis
Deacon's Avatar
I got my parts in today (well the switch today the pigtail had already come in)...
Deacon is offline
post #25 of 69 Old 05-21-2010, 03:52 PM
LuckRider
LuckRider's Avatar
Deacon, you are planning on swapping in a 241?
Support Our Troops!
JFI Member #7:
post #26 of 69 Old 05-21-2010, 04:02 PM
Deacon
Shining Adonis
Deacon's Avatar
Yes...
Deacon is offline
post #27 of 69 Old 01-24-2011, 01:15 PM
rieveskp
no idicator lights no lockers
i have an 04 rubi and my 4wd indicator lights and my lockers are not working is this what i need to do
rieveskp is offline
post #28 of 69 Old 01-24-2011, 02:16 PM
Deacon
Shining Adonis
Deacon's Avatar
No, it's not. Replacing the switch may help if the switch is bad, but that's it.
Deacon is offline
post #29 of 69 Old 03-14-2011, 09:52 AM
MattGATRTJ
Does anyone have any experience with the opposite of this situation. Say I removed the 241 from my Rubicon and installed a 231, now I cannot get the 4wd light to work properly. Using an older switch from a 231 does not work at all on the 06 rubicon. If I put the 241 switch in the 231, then I can get the 4wd switch on in 2wd along with the CEL. The switch button is too long and will not let you shift the t-case. I can fix the shifting problem, but the CEL and getting the switch to function in the opposite position is not possible.
I have not found any info on this.
I know "why would you get rid of a 241?" Cause it goes great with a D30 & D35.
MattGATRTJ is offline
post #30 of 69 Old 03-16-2011, 12:05 AM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
subscribed to thread
Group W Bench
CRAWLING 98 is offline
transfer case vac switch xxgunrunnerxx YJ Wrangler Technical Forum 7 12-08-2009 01:59 PM
transfer case switch? dwaynetm1 YJ Wrangler Technical Forum 3 05-19-2009 06:16 PM
NP241J 4WD Indicator Light Switch joe130 TJ Wrangler Technical Forum 1 12-17-2008 08:55 AM
rock trac rubi t-case..where to buy one? dealership only? premo JK Wrangler Technical Forum 5 11-25-2008 11:23 PM
Transfer case vaccuum case switch Hambne YJ Wrangler Technical Forum 7 07-11-2007 04:36 PM
