#1 | ||
Against Shiny Things
NP231 Tansfer case fluid +3 or +4
Yahoo answers says
#2 | |
Go Jeepin
As long as the fluid has the correct label, it will work. Transfer Case -NV231 Part-Time (Command-Trac) - 2.2 Pints (1.0L) Dexron III/Mercon or ATF+3 or ATF+4 Type 7176 -NV242 Full-Time (Selec-Trac) – 2.85 Pints (1.3L) Dexron III/Mercon or ATF+3 or ATF+4 Type 7176
. FOR SALE: Wide Track CJ-7 Dana 44 rear axle. PM me for details A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases. |
#3 |
They are backwards compatible. The ATF+4 is just made to meet a newer spec. If your specs show ATF+3 you can use either, but if it says ATF+4 you wouldn't want to use ATF+3.
#4 |
Do it right or not at all
![]() Join Date: Jan 2003
The 231 transfer case is totally care-free so far as the type of ATF it gets, it is the automatic transmission that is very fussy that way. It will be just as happy with ATF+3 as it would be with ATF+4, and it would actually be happy with any good quality ATF. The owner's manual only specifies a particular ATF for the 231 transfer case so as to match whatever the automatic transmission for that model year requires.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#5 | ||
and as you said. +4 will work. I can buy either of the three. It's often very cold here, is Dexron II better than ATF+3? (or vice versa?) Quote:
#6 |
In EXTREMELY cold conditions like you can get there in Wyoming, I'd go with a fully synthetic ATF+4. Synthetics flow better in extreme cold.
#7 |
#8 | |
#9 | |
If anyone is looking for more on ATF +3 vs +4 this is a good link.
Chrysler transmission fluids: 7176, ATF+3, ATF+4 Quote:
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
