NP231 swap from np241OR - JeepForum.com
post #1 of 4 Old 11-22-2010, 08:24 AM Thread Starter
yogi250cc
Okay,
I don't want negative comments here. I am just asking for help. I am taking out my 241OR and replacing it with a NP231. I understand that the 241OR has an electronic speedometer on it and the NP231 has a analog speedometer on it. What do I need to do to make this swap?
2006 RUBICON
with new to me dana 30 and dana 35 rear
(dont wanna talk about it)
yogi250cc is offline
post #2 of 4 Old 11-22-2010, 08:27 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
the NP231 is really an electronic speedometer. its all electrical signal after the sensor. the NP241OR uses a tone ring, the stock NP231J uses a speedo gear, both send electronic signals to the PCM. the plug should be the same, and it should hook right up. You can also get a NP231J with a tone ring, from www.jbconversions.com ...you'll need an SYE with your lift height anyway.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 4 Old 11-22-2010, 08:32 AM
breckboarder55
IIRC the 231 needs to have a short 23 spline input.
Someone else will probably know better, but you might need a driveshaft since the Rubicon has a shorter yoke? (Possibly wrong)
I want to hear this story...
To Veterans past and present, thank you for your service!
99 Jeep Wrangler-Just another TJ on 33"s
55 Dodge Royal Lancer- Resto Project
87 Mazda RX-7 Turbo II-Built.
87 Mazda RX-7 SE-Burn Victim
01 Honda S2000DD
breckboarder55 is offline
post #4 of 4 Old 11-22-2010, 09:09 AM
Unlimited04
yea, sorta. If the OP has a 42RLE, he'll need the short input shaft (1-3/8" long from shaft face to mounting face). If he's got the manual, it's not an issue...long or short should work. all NV241OR's had short input shafts.
also worth noting you need a newer NP231J, 1996+. Shafts are different before that.
Useful Write-Ups:
Funny:
np231 , np241or , swap
Torque specs for Double Cardan Driveshaft to NP241OR output flange andito77 TJ Wrangler Technical Forum 5 05-17-2013 04:51 PM
np241or parts Alex98 TJ Wrangler Technical Forum 8 08-30-2010 02:28 PM
Atlas II vs NP241OR AlexGeorgakis TJ Wrangler Technical Forum 95 05-15-2010 10:35 AM
replacing the output of a np241or Dink TJ Wrangler Technical Forum 0 02-13-2009 08:58 AM
Blown NP241OR...anyone else with this problem??? XXX_4X4 TJ Wrangler Technical Forum 7 01-22-2009 09:56 AM
