NP231 - New Rear Output Seal Leaks - JeepForum.com
post #1 of 8 Old 11-27-2013, 06:37 AM Thread Starter
Lummoxx
Hi all,
I discovered a leak in the rear housing of the tcase. It was bad enough that the dirt and debris under the tcase was a wet sludge sitting on the skid plate, so I figured I should fix it.
I disassembled the tcase to the rear housing, put new gasket stuff on it, and then put it all back together.
For reassembly, I put in a new snap ring, rear output seal, and oil slinger.
The rear housing leak is gone, but now the rear output is flinging a lot of fluid. A much worse leak than the housing ever was. I took my time installing it, the edge is seated all the way around the lip of the rear housing, I made sure of that, and then spent another couple minutes tapping it a bit more, just to be sure. I suppose it could still be in wrong, but I don't know how, offhand.
I did some reading, and the likely culprits are that the shaft is slightly worn where the old seal was and conformed to it, where the new seal doesn't, or a defective new seal, but it looked good to me before I put it in. It had a bead of red lubricant around the inside already, so I didn't add anything before putting it on. It went on with no trouble, I didn't have to force it, and it seated snugly.
I'm just trying to get some idea of what is going on. I don't want to buy another seal just to have it leak as well. What are the likely mistakes I made? I know the assembly order is correct, it really only goes one way. (snap ring -> seal -> slinger).
Thanks.
Lummoxx is offline
post #2 of 8 Old 11-27-2013, 10:12 AM
fire239
It's a common problem. The seal has to slide over the groove where the snap ring sits. This deforms the inside of the seal and it will leak. I installed three seals till I found the answer. Wrap a piece of electrical tape around the shaft covering the groove. Install the seal then remove the tape. It shouldn't leak after this.
fire239 is offline
post #3 of 8 Old 11-27-2013, 10:56 AM Thread Starter
Lummoxx
In this transfer case, there is only 1 snap ring groove, and it is in front of the seal.
Lummoxx is offline
post #4 of 8 Old 11-27-2013, 06:17 PM
fire239
Are you using a seal tool to place the seal so there is equal pressure around the edges of the seal when seating?
fire239 is offline
post #5 of 8 Old 11-27-2013, 07:26 PM Thread Starter
Lummoxx
Heh...a seal tool? Nope, don't have one of those. Link?
Lummoxx is offline
post #6 of 8 Old 11-27-2013, 08:01 PM
fire239
No link, but I cut a youth aluminum baseball bat in half the same diameter as the metal part of the seal. Use the open cut end on the seal and tap the handle end with a hammer to seat the seal with equal pressure around the circumference.
fire239 is offline
post #7 of 8 Old 11-27-2013, 08:10 PM
sc00bz
Are you certain it is the seal? I replaced mine this past Sunday only to have a leak on Monday. At work on Monday, I utilized duct tape to tape a rag around the speedo housing where it meets the tailshaft housing. Using this method, I realized that only part of my leak was fixed by replacing the output seal after a short 3-4 mile drive. The rest of the leak came from the mating surface of the speedo telling me the large o-ring was bad. I stopped by the dealer the same day and picked up an o-ring for about $6 and pulled the old one once I got home. Sure enough, it was in terrible condition most likely due to me not inserting it quite straight enough thereby tearing the ring. It was a terrible leak. When installing the new o-ring, I put a light film of RTV on it and the mating surface on the tailshaft housing and no more leak.
The only reason I bring that up is due to you saying you pulled the tailshaft housing and could very well have damaged the speedo when pulling/installing it back in after resealing the housing.
97 TJ with some stuff.
sc00bz is offline
post #8 of 8 Old 11-30-2013, 11:08 PM Thread Starter
Lummoxx
Actually, no I can't be certain it isn't the speedo. Thanks for the tip, I'll check that out.
Anyone have any tips for pulling the oil slinger off without damaging it, and without the really expensive puller tool made for it?
Thanks!
Lummoxx is offline
