#1 | |
NP 242 selec-trac in a TJ?
Just like the title says anyone ever seen/done it? Im curious if it would work in my TJ because the fulltime 4x4 would be great to have here in UT and they can be had for dirt cheap in good working condition..
any thoughts?
Duff. [COLOR="Silver"]98 ZJ 5.9[/COLOR] [COLOR="Green"]96 ZJ Laredo[/COLOR] [URL="http://www.jeepforum.com/forum/groups/utah-jeepcrew/"]UT Jeepcrew #13[/URL] [QUOTE=southerngirl]McDuff ftw[/QUOTE] [SIZE="5"][URL="www.nightcrew.org"]NIGHTCREW[/URL][/SIZE] |
#2 |
Too little time
I don't know what is required, but it would have been a nice option in the TJ. My wife's KJ has Selec-Trac (which was an option over Command-Trac) and we use it all the time whenever the roads are wet or in mixed road conditions during winter.
#3 |
Ignore this post!
2004 Jeep Wrangler Unlimited, Automatic RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers - Power Door Locks with Keyless Entry Build Project Thread Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ Last edited by Alexia; 05-30-2009 at 09:01 PM.. |
#4 |
what about one from a ZJ? same story?
#5 |
Too little time
Okay, found this write up. A guy lost fluids in his 242 and found a 231 for cheap. Interesting read.
http://www.hobbyguild.com/jeep/index.html Also, found this on just general information on the 242. http://www.ezinearticles.com/?Jeep-Select-Trac-NP-242-Transfer-Case-Information&id=281045 Like I said, I think the 242 is a great option for it's full-time. The wife and I drove the KJ about 3,000 miles two winters ago and I kept the full-time engaged for most of the trip. |
#6 |
great atricles... not quite the info im lookin for but definitely a start
#7 |
Ignore my previous post. I was thinking about the clocking on the AW4 transmission itself. The transfer cases are fine.
2004 Jeep Wrangler Unlimited, Automatic RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers - Power Door Locks with Keyless Entry Build Project Thread Rocker Guard Comparison Chart - Final Differential Gear Ratios - Oxygen Sensor FAQ |
#8 |
so no swapping input/output shafts or anything like that? just a direct swap basically?
#9 |
Most newer ones should all be 23 splines in and out.
#10 |
ive been reading and all i could find are 21 spline 242's...
#11 | |
The only odd ball transmission on Wranglers that I know of is the AX5 with the 21 spline output.
#12 | |
Man I've been wanting to do this to our 2 YJ's forever! We also have a WJ with the 242 & I love it!
![]() Here is a link to an article I found, maybe you've already seen it, but it looks very doable! There is some difference in DS length, because the cases are different dimensions, but it doesn't seem to be a huge problem. http://www.weatherlover1.com/jeep/242.htm BTW, some ZJ's (very few!) came with AX-15 trannies (23 spline output shaft) and I'm pretty sure those had the NP242 and not the NP249. Crawlin' this thread! Max ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#13 | ||
![]() I can't remember...... ![]() Max ![]()
#14 |
soon as i find one im gonna try puttin it in...probably make a write up if all goes well
#15 | ||
Max ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
