#1 | |
NP 231+SYE vs NP 241 swap
Hi Guys,
I have a 97 TJ with the AX-15 manual transmission, and 2" BDS lift. When I lifted my Jeep, I had to drop the TC to get rid / reduce driveline vibrations. I have now got some cash saved up to fix this properly and put in a double cardan rear drive shaft. My initial plan was to install a standard SYE from JB conversions, but my thoughts are now running to swapping out the TC to a 241 from a JK Rubicon, assuming I can find one at the right price. Would this be a direct bolt out - bolt in swap? Any pros or cons either way? Bye for now ![]()
1997 TJ Soft Top/ Half Doors 4.0 I6 with 5 Speed Manual | K&N Panel Filter | D30/D44 | 3.07 Gears | Banks Torque Tube Header 31*10.5 R15 Maxxis Trepador Radial Tyres | 2" BDS Spring Lift | Bilstein 5100 Shocks | JKS Discos | JKS Rear Swaybar Links | 100W Narva Spotlights |
#2 |
Its not quite a direct bolt up for you. You have to do some skid modifications to get it to fit, since there was a change in the skid after 03. Theres a write-up on here somewhere about it.
I personally chose to do the NV241J instead of a NP231J + SYE, mostly because I have a 42RLE and can buy a Rubicrawler. This basically gets a 4-speed box, without the need to change driveshafts, and without major mods - will basically look stock. - plus I don't loose gearing. The major thing you need to ask is if you can accept going twice as slow. The 4:1 is often called too slow by some people, and they wish they had 2.72:1. 4:1 is AWESOME in rocks, but not good on sand or in snow. 2.72:1 is much better in snow and sand, but works OK in rocks. As for a NV241J from a JK - thats a good idea, if the spline counts, shaft lengths and bolt patterns are the same. The JK has both 2.72:1 and 4:1 versions of the NV241J.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 08-25-2009 at 11:23 PM.. |
#3 |
I'm a big meanie head
I too have been tossing the idea of a JK transfer case around. Since I'm swapping in JK axles and doing a little stretch, it would make the DS work a lot easier. I just don't know yet, I've not compared costs yet. Where are you sourcing your 241 from Unlimited?
::SELLING:: Hornblasters Shocker S4 horn set with some extras $210 shipped. (It is not OBA, just an accessory for OBA) "LCOG" isn't cheap and it certainly isn't easy. If you think so, you are doing it wrong. If you aren't willing to put in the effort, don't label your build "LCOG". You are just a cheap ******bag. |
#4 |
mine is from a 2005 Rubicon auto w/ 26k. got it from Gerald(provelogear) of Savvy Off Road. its wheeling next to the futon until I can afford everything else that goes along with the swap....AA cable linkage, new driveshafts & adjustable control arms.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#5 |
Ah, I was under the impression you were doing the JK transfer case. NM. Thanks though.
#6 |
will a 241 bolt into a 2.5L w/ AX5 tranny ?
-my build thread- |
#7 |
that i dont know.. as for someone that has a 241 in their jeep its bloody fantastic.. Just finished Rubicon run this week.
Ask if any rubicon owners would swap to a 231 and see what they say.. i think its the best mod i have done and if it went wrong i would get another in a heart beat.. it was bolt in for me on my 99 6cyl Skid plate mod is easy to do.. PM me if you have any questions. Dave
4" clayton long Arm, with 5 inch rear stretch. 1" BL,35" BFG KM2muds, 1" MML from Brown Dog. Rear Dana 44 Locked with a Detroit also trussed on Alloy Shafts & 4 point triangulation. Rear disc conversion. AtoZ Cage. Rubicon OR241 4:1.. Up front a D30 locked with an ARB, Alloy Shafts and HD steering linkages. Clayton belly up and oil pan skids, Rokman tank skid, PSC Rocker Knockers, ORO Swayloc, Onbard Vita 450 and tank for fills and ARB compressor for the locker. Covered in dents. |
#8 |
if it bolted on to your ax15 it prob means the spline count is different then? ( for bolting on a ax5 )
-my build thread- |
#9 |
Do it right or not at all
![]() Join Date: Jan 2003
No, the spline counts on the AX-5 tranny output shaft and 241 input shaft are different.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#10 |
Thanks for the feed back. Just to clarify I am thinking of putting a 241 from a JK into my TJ - we did not get the Rubicon TJ over here, so the only source of 241 transfercases would be from wreaked JK's
Good point about the 4:1 gear ratio, there is a guy in our club with a JK Rubicon who has done a lot a Jeeping in it, so I will ask him how he finds the gearing and decide from there. I did not realise that the 241 came in both gear ratios, might have to look into that a bit more. Modifying the skid for the new transmission mount is not too much of an issue for me, I was more wanting to check that it would bolt up to my AX-15 with no worries?
#11 |
I have two questions the first is would it bolt up to an ax-15 in my 91.... are the splines in the ax-15 the same through the years....
so I have a similar question as the OP. Would it be better for me to buy a Tera 4:1 kit and SYE kit for my 231 or get a NP241 and buy a SYE for it??? |
#12 | |
The 241 doesn't have a SYE (it would need a slip yoke in the first place for it to be eliminated) - its got a fixed flange output. This allows you to bolt a CV shaft on it, which has a fixed yoke end...very similar to a SYE.
#13 | ||
i've been thinking about the very same thing. i haven't done enough research into what it takes to swap a 241 onto an ax-15, which is what i have. if you compare the costs of a sye and terralow 4:1 conversion to the price of a 241 it makes a lot of sense.
#14 |
I swapped a 241 into my '98 TJ and loved it. In situations where the 4:1 was too low I simply selected a higher gear in the transmission. 2nd gear w the 4:1 is essentially the same 1st w the 2.72:1 box.
#15 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
