#1 | |
NP 231 or NV241
Hey, I have an 05 TJ X 6spd with a RE 3.5 lift. I was wondering if i should get the SYE kit to eliminate driveline vibrations or should i just swap my NP231 with an NV241....? I found and NV 241 at a decent price but i would like to know if the NV 241 is a bolt on replacement to my NP 231 or do i need and additional modifications. Form what i've heard the transsmision mount might need modfication due to the larger NP241.... iS THIS TRUE...??
#2 | |
Never Forget
how much you talking? cause you also gain a 4:1 lo gear id get it, all youd need is trans mount from a rubi
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers Quote:
www.cityprofile.com |
#3 |
i found the used Rubi t-case for $750 with 7000 miles on it
#4 |
You'd need to replace your shafts as well. The Rubi uses a shaft with a slip-joint in the shaft itself.
#5 | ||
Never Forget
to the OP id do the rubi case if it was me, new case + SYE + 4:1 lo = ![]()
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
