Quantcast Novak T-case shifter - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Novak T-case shifter
Old 01-15-2006, 10:39 PM   #1
blacktj27
I ordered a Novak T-case shifter and was wondering if anyone has installed one before. If so what words of wisdom do you have and are there any good wright ups about it?
Thanks
04 TJ Sport (Black)
AFW front bumper, ARB snorkel,
windshild mount KC Daylighters,
dana 44, 3.73 gearing, KC fogs,
RE3.5, 32x11.5 Kuhmo MTs,
KC backup lights, PSC diff. guard,
LoD bumper/tire carrier,
1"MORE MML, 1.25" JKS BL,
Pioneer AVIC-N2, Ultimate Air,
Novak T-case shifter, Warn 9.5ti,
PSC dana 44 bomb shell
blacktj27 is offline   Reply With Quote
Old 01-15-2006, 10:43 PM   #2
biffstephens
Use a coat hanger as a template.....I am going to tack my self on and say that I will have one forsale shortly....I am changing transfer cases is the reason.....it has the black knob by the way....PM with intrest.....
Also, fab a boot for it. Leaving an open hole in the floor will let a LOT of hot air through....
Besides that happy shifting....
Wheel Spacers? Aluminum Fairleads? Winch Rope? LEDS? Winches? Accessories..... [URL=http://www.Offroadoverstock.com ]
Visit Offroadoverstock.com [/URL]
Biff
biffstephens is offline   Reply With Quote
Old 01-15-2006, 10:54 PM   #3
BigWaylon
tubework is cool...
BigWaylon's Avatar
I just pulled mine off...but LOVED it while it was on...Atlas went in last week, so I don't need it anymore...
getting it bent just right is a pain in the butt!!
ditto on the boot...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote
Old 01-15-2006, 10:58 PM   #4
BigWaylon
tubework is cool...
BigWaylon's Avatar
found a pic:
that's how mine ended up being bent...
also...just a suggestion...once you get it all setup to work properly, tack the threaded rod on one end...I had mine fall out the first time on the trail, and we just jammed it into 4LO for the rest of the day, til we could get off the trail and see what was going on...
Greg
Old 01-15-2006, 10:59 PM   #5
FifteenCents
check out this link....
http://www.rockcrawler.com/techreports/novak_shifter/index.asp
The above post is my opinion and I have no facts to prove it... :)~
http://www.tjhardcore.com
The ultimate TJ owners only forum
FifteenCents is offline   Reply With Quote
Old 01-15-2006, 11:03 PM   #6
blacktj27
Originally Posted by BigWaylon
found a pic:
Greg
wow that is a lot of bending. That is going to suck!
04 TJ Sport (Black)
Old 01-16-2006, 04:19 AM   #7
tommaho
There was a long thread on another forum (link below) where a Novak rep explained that in most situations a single 50 degree bend should be the only one you need with all the mechanical adjustment the linkage provides.
http://www.jeepsunlimited.com/forums/showthread.php?t=612940&page=1&pp=20
I didn't get the shifter yet, but read the first few posts closely for a frightening account of how *not* to install it.
Tom
tommaho is offline   Reply With Quote
Old 01-16-2006, 09:25 AM   #8
igofshn
Locked @ both ends
igofshn's Avatar
Mine looks like waylons, but according to the guys at novak, you only need to bend it once. The JU thread has pics.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
[Jeep Pics
igofshn is offline   Reply With Quote
Old 01-16-2006, 09:36 AM   #9
FifteenCents
Originally Posted by gpw1942ford
If you read the above link it will tell you that the old mount was a off which is why the above rod is bent so many times...the new bracket is the right angle so you do not need so many bends to get it to fit through the console.
Old 01-16-2006, 11:00 AM   #10
wdstj
I have been running this shifter for about 6 months and I really like the way it shifts. I will second the need to keep the threaded rod from falling out. It happened to me on my first trail. I used blue Locktite and it seems to be pretty solid. The only thing I don't like is that the entire shifter mechanism is metal and solid, which transmits transfer case noises into the cab at freeway speeds. The stock shifter is isolated with plastic. Anybody else have the same problem?
wdstj is offline   Reply With Quote
Old 01-16-2006, 09:53 PM   #11
BigWaylon
tubework is cool...
BigWaylon's Avatar
mine was loud because I never put a boot on it...
the problem I had with it being all metal and solid was it got HOT after driving to the trail at highway speeds...
Greg
Old 01-17-2006, 02:10 AM   #12
blacktj27
Greg
How hot did the thing get? Because that is a problem that I have never heard of before.
04 TJ Sport (Black)
Old 01-17-2006, 05:48 AM   #13
BigWaylon
tubework is cool...
BigWaylon's Avatar
you didn't want to have to hold onto it...you could move it, still...not like it was glowing red...
probably wouldn't be much of an issue just on the trail...
but you've got a solid metal link going straight to a t-case/transmission that is getting fairly warm...
Greg
Old 01-17-2006, 06:39 AM   #14
BillR
BillR's Avatar
Greg
That's the issue!
I put a CJ boot under the console when I had a Novak on my old XJ, but I never could get it quiet in the cab again. I still had a good ammount of road noise coming in.
'05 LJ Sport, 6-speed, SwayLoc, LoD bumpers...the build begins!
'11 JK Unlimited Sport S, stock for now...
BillR is offline   Reply With Quote
Glock Forum
