Novak shifter install -- bending the cane
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
I'm at the step in my Novak install where I need to bend the shifter cane to fit.
I've heated it with a small Benzomatic MAPP torch but I just can't seem to get it hot enough to bend. I've got it in a vice and I've tried bending it by hand while wearing welding gloves and by hitting it with a small sledge. Should it glow red-hot at the bend point? Because I can't get it there with the MAPP. Do I need to use acetylene? Any other tips?
'98 Sport, 5spd, 3.73, AA SYE, TW driveshaft, JKS 1.25" BL, Rokmen gas tank skid, D30 Lock Right and Alloy Seals, Cobra 75WXST |
#2 |
Yeah it needs to e glowing a the bend.. I took a pipe and put it over to help bend it.
Finally paid off... |
#3 |
do not quench it. it could snap when used.. let it cool on its own.
97 TJ 4.0, AW-4, Clayton, A.R.B., Highly polished HP30, Super 88 There are no shortcuts to any place worth going 91 XJ 4.7 |
#4 |
Bump for the afternoon...
I'm definitely not going to quench it. Anyone else used MAPP to bend their Novak shifter? I swear I was heating it for 30 minutes yesterday and could not get it glowing red.
#5 |
I used MAP on mine, but as stated above I also put a pipe on the end for more leverage.
#6 |
Beware of heat sinks
When you heat in a vise it is often best to make sure your bend point is not near the jaws. They will suck up huge amounts of heat. Set the bend point a few inches above the jaws at least. It will bend where you heat, don't worry.
04 Rocky Mountain Edition TJ Flame Red 4.0L with 5 spd Dana 44 3.73 rear with Trac-lok 30x9.5x15 GY SA on Alcoa Forged Red Jeep Club #486 |
#7 | |
Oh BTW, once the shaft is where you want it toss some Brats on the grill and enjoy.
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#8 |
Do it right or not at all
![]() Join Date: Jan 2003
MAPP works fine, that's what a friend and I used to bend my Novak shifter rod. However, it's still not an easy bend even when cherry-red hot. A steel pipe slipped over the rod to increase the leverage is what it took to get mine bent as precisely as it needed to be. Make sure you don't booger up the threads when doing so, I did and had to use a die to clean up the threads before I could screw the shift knob down onto it.
Once bent and you're installing it, make sure the two bolts for the clamp that hold the rod in the shifter are TIGHT TIGHT TIGHT!!!. Getting it tight enough to prevent the shifter rod to rotate to the side at times proved impossible for me. I ended up tack-welding mine to the moveable part of the clamp on Saturday which finally took care of the shifter rotating out of position problem.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
