Quantcast Novak Adjustable Transer-Case Shifter Linkage???? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Novak Adjustable Transer-Case Shifter Linkage????
Old 07-12-2006, 02:42 PM   #1
kaketj
beef jerky and grease....
kaketj's Avatar
okay,who has this and how do you like it after you istalled it.thanks
"shoot first,we have shovels"
2004 X w/ RESF 4.5- super 44/44 w/arb 35x12.50R15mt/r- all armored up! Warn 9.5 ti(front) 9.5xp(rear) (SOLD)
1999 Cherokee sport (build in progress)
New toy. ZO6
kaketj is offline   Reply With Quote
Old 07-12-2006, 02:48 PM   #2
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I have the linkage installed now, but i just haven't bent the rod because i'm wanting to do a belly up skid and I don't want to bend the rod twice.
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 07-12-2006, 02:49 PM   #3
newbs
Jeepaholic
I have it but it's not installed yet.
newbs is offline   Reply With Quote
Old 07-12-2006, 02:52 PM   #4
nolie
Just completed the install. I like it, took longer than I thought it would. A few issues I do have, 1. When you remove the stock shifter your left with a good size hole. I am told a shift boot will fix this, 2. after driving for some time the novak shifter gets very hot. dont know if the shift boot will help this or not, I have been looking to correct both issue
nolie is offline   Reply With Quote
Old 07-12-2006, 05:41 PM   #5
kaketj
kaketj's Avatar
So this completly replaces the shift linkage/ handle that is accessible in the cab(does it install on the body or the t-case?)? and you can't use the original boot on the T-case shifter? heat issues(how hot?) and what about bending the rod? just don't want to spend twice if I don't have too! thanks for the replies
New toy. ZO6
Old 07-12-2006, 06:21 PM   #6
YJscott2
i have one in my YJ and they connect to the same spot as ur stock one does.
i like mine.
i think the heat is bc he dosnt have any boot on it. thats all it could be. its not like their is energy goin through the handle to heat it up its just from the Trannyand Tcase. you have to have differant rods when you do a belly up skid or a BL. its the rod that goes from the handle to the lever on the T case
YJscott2 is offline   Reply With Quote
Old 07-12-2006, 06:56 PM   #7
nolie
The novak mounts to the t case not to the body. Kaketj theres no original boot for the T case, The stock 4wd handle mounts to a metal plate No boot. YJscott I didnt need any other rod that what came in the kit, I have 1"bl in my TJ. Right now with out a boot to cover the hole over the t case the handle does get very hot. Bending the shift handle wasnt hard. again it is a great kit and shifting is so easy now.
Old 07-12-2006, 07:38 PM   #8
kaketj
kaketj's Avatar
your right there isn't a boot! I was thinking of the manual clutch shifter thanks for the info
New toy. ZO6
Old 05-22-2007, 10:58 AM   #9
qf4phlyer
qf4phlyer's Avatar
Looking to upgrade to the Novak Adjustable Transfer-Case Shifter Linkage. Any updated from those who have it installed?
08 Wrangler X DETN8R Yellow Rough Country 2.5" progressive rate coil lift, 2.2 shocks. 1.25" body lift, disco's, steering stabilizer. Benchmark EVAP skid. TeraFlex front bumper with shackles. 35x12.5x15 BFG A/T KO's on MB72 wheels.Cobra 75 on a Firestik. Arizona Rocky Road antenna mount. Ward bug shield, DayStar hood wranglers, upper dash panel. Qtech arm rest.
2002 Wrangler Sahara RIP
1979 CJ 7 258 RIP
1975 Cherokee S 401 RIP
qf4phlyer is offline   Reply With Quote
Old 05-22-2007, 12:19 PM   #10
Bigbob
Bigbob's Avatar
Look over at the Rubicon Owners Forum, they had an extensive thread on the Novak not long ago. A slightly different T/C, but still a lot of good info. It seemed to be all positive stuff on the Novak.
I guess the shifter on The T/C has a nut that needs to come off that's a real bear. This may just be on the 241 though. Sealing the floor is an issue most have resolved by getting a generic shifter boot from the locall auto parts place and installing.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline   Reply With Quote
Old 05-22-2007, 12:51 PM   #11
JeepRocks86
overall the installation on the 231 is easy. if you don't have the front of the center console in you can run it with out bending the rod. I did this with the stock tranny skid and 1" bl as well as my flat skid and 1" BL. (stated in first reply)
eventually i will get around to bending the shifter since my belly up is finished.
My Build Thread.
For Sale:
Old 05-22-2007, 12:54 PM   #12
sparkeep
I have installed mine (still not quite finished as I have to plug the hole in the body better) and I love it. There are a few things that make the project take longer than you think...
1) The torx in the stock arm on the transfer case took me and a buddy 3 hours to remove. May be only the 241 case that is a problem (as stated)
2) Finding the correct holes that produce the shifter throw you want in the cabin can take a while. Then determining the bend in the shifter to pass through the hole also, takes a while (although I'm a perfectionist so maybe it will be easier for others).
3) Eliminating noise through the hole I haven't completed but by making a knob out of delrin/nylon makes the temperature normal. Not too hot in summer and not too cold in winter.
When you remove the stock shifter, you can use the metal mount plate (once you cut the middle out) as a frame for clamping shift boots in place.
2005 Impact Orange Rubicon
6 speed standard 4.0L I6 engine
Mechanical Engineer behind the wheel
Toronto, ON, Canada
sparkeep is offline   Reply With Quote
Old 05-22-2007, 12:59 PM   #13
fyrfyter43
The hardest part of the install is bending the shifter. It just takes some patience to get it right.
Here are a couple pics of it installed.
linkage at t-case:
2-hi:
4-lo:
fyrfyter43 is offline   Reply With Quote
Old 05-22-2007, 01:12 PM   #14
Olsen
Junior Member
Novaks shifter just plain rules. The high heat factor is a very real issue and one that is being dealt with. The heat you are feeling is residual heat coming off of your engine and into the gaping hole that is where the shifter is, look at it this way. The original shifter is big and plastic that was held in a cocoon of sorts, plastic will shed heat rapidly. Novaks shifter is all steel with an aluminum knob and we all know how aluminum will absorb heat like theres no tomorrow. Also there is no cocoon or cage around their configuration to help divert the engine heat.
Novak is working on the 'cage' configuration even as we speak so the heat will be diverted. As an aside; I put foam rubber in the gaping shifter hole before my panel was re-installed and this helped some. The transfer case oil temp was checked multiple times when I first installed my shifter and experienced the heat factor, I found no alarming changes between stock shifter oil temp and Novak shifter oil temp. You could fabricate your own air dam around your shifter with sheet metal if you were so inclined also. Been using mine for over a year now and love it!!
Olsen
Olsen is offline   Reply With Quote
Old 05-22-2007, 01:49 PM   #15
JeepRocks86
what I did for the hole was went to pep boys and got a Hurst Shifter boot. It was the only one I could find at the local places that had a plate that screwed to the bottom as opposed to just fitting in the hole. It has 4 screws that went through the body to cover the hole. I still haven't done anything about the 4 other holes where the factory shifter attached. I plan on using some rubber plugs, but i keep forgetting to look for them when i'm out
My Build Thread.
For Sale:
Glock Forum
