Quantcast not your average gear question...maybe - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > not your average gear question...maybe
Truck-Lite's New LED Headlamp SeriesNEW! Poison Spyder RockBrawler BFH Bumpers!Poison Spyder BFH Rear Bumpers
Old 03-08-2006, 10:13 AM   #1
LJPeej
got percision 4.56s that have about 2000 miles or so on them..........well when i get to exactly 70 mph and above it starts to whine when you press the gas but then stops if you go anything under 70. Im a little worried since this is the 3rd set of gears in the back because the other two were destroyed along with the rear end * brand new 44 now*......does anyone else have this problem , or should this be something that i have to look into more
05 Unlimited
RE 4.5 - PSC Sliders - ARBs - 4.56s - 35s
LJPeej is offline   Reply With Quote
Old 03-08-2006, 08:17 PM   #2
yellj
Who did your install, did they add drainage slots, I had to expand mine to a half inch on bith sides. What oil and diff cover are you using? Are you venting any oil from your breather tube, would drip oil near your gas tank by the filler neck?
04 Unlimited RE SF 4.5", 1" MORE BL and MML, ARB Bull Bar, AR23 15x8, 35x12.5 MTRs, Jeep Medic Engine and T/F Skid, Shrockworks Rockers, Warn 9.5ti, AA SYE, ARBs, 4.88s and Alloy USA Shafts, HPD30 w JJs 1967 M416
www.midatlanticjeepers.com
yellj is offline   Reply With Quote
Old 03-09-2006, 02:10 AM   #3
LJPeej
i had the install done at the carolina rock shop.....they did a great job and always helped me when i needed it would def recomend them....but anyway im running a blue torch fab cover and yes there has been leakage that has pretty much stopped,im pretty sure they didnt add drainage slots, and i forgot what kind of fluid im running.....white bottle thats all i remember......would i be able to do this drainage slot thing?
05 Unlimited
Old 03-09-2006, 10:40 AM   #4
yellj
The drainage slots are internal below the axle tube in the interior of the diff housing. I've heard good things about them, but if they didn't add them, they need pull the locker and grind in the slots, we went in a second time to enlarge the slots. Here's a link with a pic. I went with Rockcrusher diff covers, which have the filler hole like a high pinion, synthetic oil 75W-140 and added a little Lucas additive. This coupled with breaking the gears in a little worked for me. No whine and no oil spewing out the breather tube. Took 3 weeks to get everything worked out.
http://www.arbusa.com/alac/alsp/5-11.pdf
Old 03-09-2006, 12:22 PM   #5
WrangBlake
hey pj, discos are fun dude
WrangBlake is offline   Reply With Quote
Old 03-09-2006, 06:22 PM   #6
LJPeej
ok thanks for the help, im gonna have to get them to look at that for me...one more question the lucas additive you added was that because of the ltd slip or for something else....i wasent sure if i needed to add it since i got new gears lockers
05 Unlimited
Old 03-09-2006, 09:19 PM   #7
yellj
Added to help with lubrication, the stuff is like glue, oil kind of sticks to it, so everything stays lubricated. I had a faint whine going from 30-40, gone now. Not sure if was the synthetic or the Lucas? We went in a second time and enlarged the slots to a half inch on both sides.
Show these directions
Glock Forum
