Not a good day today. :( - Page 2 - JeepForum.com
post #16 of 40 Old 08-25-2007, 08:41 PM
fromme
fromme's Avatar
1977 CJ7
Originally Posted by BillR
I'm "guessing" he tried to drive without front axle shafts...
Sadly, been there, done that...
Ok, this is seriously not a flame, but how the hell could you think you could go down the road without front axles? Obviously more than one person has tried it, but it seems obvious to me, trying to figure out how one could come to the conclusion it would work.
To the OP, I would find someone to weld a nut on the screw head, then heat it up real good and wrench it out before you break it off and have to drill the whole thing out.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
post #17 of 40 Old 08-25-2007, 10:38 PM Thread Starter
CHRRRIS
CHRRRIS's Avatar
Awsome! I went to a local welding place today and they got it out easily! They heated it up, chizeled the **** out of the top, heated it some more, sprayed some stuff, welded on an entire Grade 8 bolt, and it came right out.. $45 and I'm happy.
These threads were far more rusted than the other one, so for no extra charge he sprayed some cutting oil in there and in a way re-cut/cut out the threads so they are smooth as butter now...
It's easier to go down a hill than up it but the view is much better at the top.
-Henry Ward Beecher
Current - '98 Black Z28 with some goodies
Previous - '97 Gun Metal Blue TJ
Northern Illinois Extreme Jeep Club
CHRRRIS is offline
post #18 of 40 Old 08-25-2007, 11:11 PM
BillR
BillR's Avatar
The front wheel bolts to the unit bearing, which LOOKS like it's pressed together pretty well. Many people (including me) didn't know that the outer axle shaft is needed to keep the bearing together. You can run fine without INNER shafts in the front, but you NEED the stub shafts in place.
My "experience" happened on my old XJ, and was quite expensive to repair. I'm thankful I was only going a few MPH as I was turning into the parking lot of Wally World.
It cost me a few bucks to fix and no one got hurt. A cheap lesson IMO.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #19 of 40 Old 04-01-2011, 08:20 PM
KevKaos
Sorry you had all those problems, but you really need to get some PB Blaster. I would bet that if you PB Blastered them and let it set for awhile and then used a 16-24" breaker bar and some slow and easy pressure, they would likely have backed right out. If not, resort to the heat treatment. Now that I know about PB, I blast all the nuts and bolts ahead of time on whatever we are working on. Quite the lifesaver.
KevKaos
Honey Badger Wheelin'
RED JEEP CLUB # 621
It's not much, but check out my build thread;
Originally Posted by krashnpa View Post
I know kev was riding his tank skid and belly pretty good on some of the blacks up at RC, but he doesn't back down from the line either.
so I use my original nuts?
You should, in no way, take any of this personally. It's just business. So to recap, I come in peace, I mean you no harm, and you all will die. Gallaxhar out.
KevKaos is offline
post #20 of 40 Old 04-01-2011, 08:33 PM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
Holy old thread batman!
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #21 of 40 Old 04-01-2011, 08:47 PM
NoVaHunter
Yeah seriously how in the hell did you even find this KevKaos?
Originally Posted by KHoff90 View Post
Has anyone really been far even as decided to use even go want to do look more like?
NoVaHunter is offline
post #22 of 40 Old 04-01-2011, 09:21 PM
ChiliPalmer
LOL - I've done it before. Either through a search or just browsing and not realizing how far back you've gone.
Forum!
post #23 of 40 Old 04-01-2011, 09:26 PM
moleary
2006 WK
Good advice is timeless!
moleary is offline
post #24 of 40 Old 04-01-2011, 10:17 PM
gebirgziege
yeah just in case he is still dealing with this pesky torx bolt after four years...
44 Ford gpw rblt all original. 06 LJ Rubicon black on black - project.
gebirgziege is offline
post #25 of 40 Old 05-16-2011, 01:40 PM
KevKaos
I ended up having a badly stripped Torx and went to the search function. Unfortunately I didnt use the search for ***** but exclude older than dog s#$% filter. Sorry guys.
KevKaos
RED JEEP CLUB # 621
KevKaos is offline
post #26 of 40 Old 05-16-2011, 01:48 PM
thirdeye
So it won't work driving without front axle shafts? I've always wondered if that would work or not...
2004 4.0L I6 TJ BUILD:
1997 2.4L I4 TJ BUILD:
http://www.jeepforum.com/forum/f22/thirdeyes-second-tj-1816002/
thirdeye is offline
post #27 of 40 Old 05-23-2011, 09:17 PM
dsapp78
good luck with that.
dsapp78 is offline
post #28 of 40 Old 09-23-2011, 07:52 AM
rockwallchamp09
by any chance you have a can of PB blaster? in most of all cases ive found that it supercede's wd40 almost 10 fold
Chuck Norris is 1/8th Cherokee.
This has nothing to do with ancestry, the man ate a Jeep.
rockwallchamp09 is offline
post #29 of 40 Old 09-17-2013, 09:17 AM
mike m2
Can you drill it out with a slightly larger size, then either re-tap to a larger size bolt, or use a nut and bolt?
mike m2 is offline
post #30 of 40 Old 09-17-2013, 09:20 AM
sjones26573
He probably tried that 6 years ago.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
What did you do to your TJ today? exc911ence TJ Wrangler Technical Forum 113785 Today 10:12 PM
