#151 | |
Looking very good love the progress. I also wanted to mention that I have voted for you in every one of the TJOTM's. I Can't wait to see the end result.
Steven |
#152 |
Thanks, I am currently waiting on some brackets from Ballistic fab. I would have liked to have gotten the jeep a spot on the first TJOTM, but I will wait and resubmit it when I get done with the build. The hardest part of this is waiting on parts to come in. Thanks again.
#153 |
you got my vote also. this is a sweet build. and knowing you and how perfect things have to be. this will be a great looking rig as well, not a cobbled up tj with truck axles. get it done. lets ride.
tellicojeeper |
#154 |
UPDATE, I got the d60 pretty much done. The brakes, bearings, hubs and axles, pinion seal, are in. I will start on the rear d70 soon. Here are some pics. I have a Ballistic fab high steer arm that will go on that passenger side, if they ever get here.
![]() ![]() More later.... |
#155 |
Before and after pic. I still have the brackets and truss to put on.
#156 |
Beefy! (10)
I got my D44 - now i need to regear - Anyone got a good place to go 'round charlotte? Building up to 35s |
#157 |
Looks good
#158 |
Ok. So I finally got the rear quarter guards, I had made the template for, back. So it was time to trial fit them and to do a little cutting.
![]() ![]() ![]() ![]() Then to make sure these were still going to work. ![]() Then I made a quick trip over to the drill press and drilled these holes, after deciding where I wanted them. ![]() ![]() These bolts are temporary, I will get some that will be flush mount. I will have to get the bolts, then I can get the correct counter sink bit. I then disassembled the quarter guards and then it was time to Say ello to my leetle freenz. ![]() This is where it got real. No turning back. ![]() ![]() Note: I moved the gas tank before grinding. ![]() I also had to cut some of the inner fender, behind the fender well. ![]() ![]() ![]() ![]() The above pic shows how far back the opening has been moved. ![]() I will also reuse 2 of the factory fender flair holes, for mounting the quarter guards. More later...... |
#159 |
I like how well the guard matches up to the rock sliders, i hate when there is a random, odd shaped, gap.
Looks nice, cant way to see the end result
#160 | |
I also got my tracking number from Ballistic Fab today. Finally. That stuff is supposed to be here Friday. I am getting anxious. I hope to be able to get some more stuff done this weekend. I am looking forward to doing some welding. |
#161 |
rear wheel well looks awesome.
#162 |
Jackstand Wheeler
what are you going to do about that rear fender hanging off the back?
#163 | |
![]() AH ha, I knew that would come up. I will cut that bass terd off. No really, I think I will cut it and try to bend it slightly inward. If that doesn't work then I will cut it right there where the license plate dirt is, on the left side, straight down. Then I will plug the end????? ![]() |
#164 |
Jackstand Wheeler
i hear ya, it would be sweet to wrap it around though
#165 |
Ya, I will come up with something. Oh, I just noticed that by my avatar says, Senior member. I hope that means that I have been here a while and that I am not old. I need to check out some of the others.
| Tags |
| bddisi, evolution, not a build |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
