Was not the Blower Resistor - JeepForum.com
post #1 of 2 Old 03-22-2007, 06:04 PM Thread Starter
tmwoodall
Ok just tried changing the blower resistor, still blowed on all settings except the next to highest. So I put the old one back In i am going to try and return it tomorrow. Does that mean that it is my blower motor going out?
tmwoodall is offline
post #2 of 2 Old 03-22-2007, 06:20 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The speeds are selected by the switch and controlled by the resistor pack. If the motor runs on all but one speed and you replaced the resistor pack already, it's either the fan speed switch itself or you've got a crispy wire in there somewhere. Mine had several burnt wires I had to replace when my resistor pack went bad.
Jerry Bransford is offline
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
Blower resistor issue? txflood3 TJ Wrangler Technical Forum 5 08-27-2009 07:51 AM
Blower Motor Resistor jecaper TJ Wrangler Technical Forum 9 10-05-2007 03:17 PM
Is this blower the resistor? Eyeguy77 TJ Wrangler Technical Forum 6 02-22-2007 07:13 PM
Blower fan switch/resistor thechrisgibson TJ Wrangler Technical Forum 1 10-10-2006 10:39 AM
