normal operating temp for an 06 tj automatic transmission - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > normal operating temp for an 06 tj automatic transmission
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deli
Unread 08-14-2010, 09:30 PM   #16
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Originally Posted by 1tufrubicon View Post
My '05 Rubi runs 155 or so on flat ground. Pulling grades in 100 degree heat I see around 180 max. Sitting at idle in the heat is a different story. I can watch the gauge move and it hits 180 in just a few minutes. I've always heard the worse thing you can do for your A/T is idle for long periods of time. I've got a B&M Super Cooler on mine.
Where is your temperature sending unit mounted?...
Knuckelhead is offline   Reply With Quote
Unread 08-14-2010, 09:34 PM   #17
Knuckelhead
AFSOC Retired
Originally Posted by littledevilTJ View Post
i am highjacking a thread for one second, knucklehead, do you have a build thread?
It's all in my head...
Unread 08-15-2010, 12:32 PM   #18
1tufrubicon
1tufrubicon's Avatar
I tapped into the standard trans cooler line that exits the radiator. So I guess it's on the return line? I've been out in Death Valley in the winter with *strong* cold winds blowing into the radiator and have never seen the trans temp get above 120 degrees and that's at slow trail speeds.
1tufrubicon is offline   Reply With Quote
automatic , tranny , transmission , operating , temp , temperature
