Normal idle rpm for 01 TJ 4.0 6cyl?? - JeepForum.com
post #1 of 5 Old 02-16-2006, 11:14 AM Thread Starter
Rick3401
Hi all,
Can anyone tell me if 600-700 rpm is normal idle for my TJ? Seems to want to cut out once in a while.
TIA
Rick
01 Solar Yellow Sport, 4.0, 5spd. 31x10.5x15. 3.07 Club member #22
Rick3401 is offline
post #2 of 5 Old 02-16-2006, 11:16 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That's a bit low, perhaps the TPS (throttle position sensor) is going south. Erratic idle is often a result of a bad TPS.
Jerry Bransford is offline
post #3 of 5 Old 02-16-2006, 11:20 AM Thread Starter
Rick3401
Thanks Jerry, you da man. My TJ died yesterday while driving. Had it towed home and discovered no fuel at the rail. Found a broken wire to the fuel pump and repaired it. Starts and runs okay but seems to idle low. I'll check that.
Rick3401 is offline
post #4 of 5 Old 02-16-2006, 01:53 PM
willy peter
Sounds pretty normal to me.
Steel Blue 2001 TJ Sport
D44/D30 with 3.73's/31x10.5 Kumho AT's on stock canyon's/Rhino-lined interior/Alpine 9856 Headunit with Infinity speakers/Teraflex disco's/Blacked out headlight bezels/Removed front flotation devices!
Planning on more, just saving up the cash.
willy peter is offline
post #5 of 5 Old 02-16-2006, 02:32 PM
grymsr
Vintage Member
grymsr's Avatar
my Tj idles around there as well but runs fine. cruising it runs about 1500 which seems rather low, but again, it runs fine. go figure.
grymsr is offline
Idle Problem...RPM's dip then return to normal ElJaynocibuR TJ Wrangler Technical Forum 10 01-27-2010 04:42 PM
Really Rough Idle: 1989 6cyl 4.2 Weber Carb. hillie4life YJ Wrangler Technical Forum 14 02-25-2009 01:03 PM
35 psi at idle normal??? platinumjeep TJ Wrangler Technical Forum 3 01-11-2009 06:40 AM
more-than-normal rpm's at idle Rubi22 TJ Wrangler Technical Forum 6 07-30-2007 12:23 PM
Oil pressure dropping at idle (not the normal drop) Laxstar46 TJ Wrangler Technical Forum 2 04-21-2007 10:04 PM
