NOOB A/C question - JeepForum.com
post #1 of 13 Old 09-04-2012, 09:02 AM Thread Starter
Barcus
NOOB A/C question
When I crank the Jeep up the a/c blows ice cold for only about about 20-30 min. If I have to idle in traffic or the Jeep sits off for a while it comes back. What could be causing this? Im thinking it cant be a leak but I know nothing about a/c systems. Any suggestions? I had the system purged, refilled and a schrader valve replaced a few months ago because it wasnt blowing any cold air.
98 TJ Currie arms-RC 2.5 coils-RC 2.0 shocks-1.25 BL-TF rear track bar-custom bumpstops-mud-scratches-gas.
Barcus is offline
post #2 of 13 Old 09-04-2012, 11:15 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Buy a $20 A/C gauge at Advance auto to tell you if it's properly filled or not.Does it blow warm after 30 minutes or not at all out of the vents?
TheBoogieman is offline
post #3 of 13 Old 09-04-2012, 11:22 AM Thread Starter
Barcus
Its filled properly. I have the gauge. It blows warm air after about 30 min. All the vents function properly.
Barcus is offline
post #4 of 13 Old 09-04-2012, 11:45 AM
TheBoogieman
Disturbed
98's are known for vacuum leaks,but usually it will blow out of defrost vents only.My 98' blew cold air until I went up hill or revved the engine.As soon as I backed off,it was cold again.Maybe someone else has had similar problems.
post #5 of 13 Old 09-04-2012, 12:20 PM
brplatz
My 98 has a vacuum leak, and an AC leak haha
The Second Amendment is in place in case they ignore the others.
That's like saying you wish your boyfriend was a bit less gay.
MOΛΩN ΛΑΒΕ
brplatz is offline
post #6 of 13 Old 09-04-2012, 12:51 PM Thread Starter
Barcus
ok, ill have to investigate the possibility of a vacuum leak further.
Barcus is offline
post #7 of 13 Old 09-05-2012, 10:52 AM
Reptile
1991 XJ Cherokee
Was the systems vacuumed up before refill? Humidity in the system will freeze up the evaporator's orifice tube as AC gets cold and water turns into ice crystals.
Reptile is offline
post #8 of 13 Old 09-06-2012, 09:57 AM Thread Starter
Barcus
not sure. Im assuming the shop did when they replaced a valve. Its a pretty reputable shop around here. It might be worth getting it done again.
BTW, I lived in Bakersfield about 25 years ago when I was a kid. Bladen st. I walked to school but I cant remember the name of the school. Castle Elementary?
Barcus is offline
post #9 of 13 Old 09-06-2012, 02:45 PM
JWebber
You could also have a faulty pressure switch. When it gets warm is the compressor still running or is it turning off???
JWebber is offline
post #10 of 13 Old 09-06-2012, 02:52 PM
gmiller0737
That's what I was going to ask,The answer to that question will help determine the next step in Troubleshooting.
gmiller0737 is offline
post #11 of 13 Old 09-06-2012, 04:05 PM Thread Starter
Barcus
compressor is still running.
Barcus is offline
post #12 of 13 Old 09-06-2012, 11:24 PM
Reptile
1991 XJ Cherokee
Doesn't ring a bell. Been living here for just 7 yrs though. I'm a little more familiar with high schools around here (football...), biggest ones being Foothill (Trojans), BHS (Drillers), Centennial (as*holes), etc. Actually live by Highland off of fairfax! Eastside iz de best
For your AC, you're supposed to pull 27-30" (Hg) of vacuum, your shop may have done it, but there's always a chance of air getting in as they refill it (bad charging hose, fittings, etc). The other thing that can cause that is the e-fan not working, if so equipped, but TJs don't have e-fans (right?).
Reptile is offline
post #13 of 13 Old 09-07-2012, 09:40 AM Thread Starter
Barcus
yeah No e-fan on mine. I think the 4 cyl Tj's have them
Barcus is offline
Noob question Tdog02 TJ Wrangler Technical Forum 11 12-31-2011 10:49 PM
RC vs RE noob question bmw91 TJ Wrangler Technical Forum 7 06-22-2010 04:57 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
Noob Question RHA1583 TJ Wrangler Technical Forum 10 01-16-2006 09:50 PM
another noob question DrD TJ Wrangler Technical Forum 5 08-10-2005 07:55 AM
