No turn signals?! - JeepForum.com
post #1 of 7 Old 05-28-2006, 09:43 AM Thread Starter
hoyttrucks
No turn signals?!
All of a sudden yesterday I realized my turn signals inside weren't coming on. I looked outside and they weren't working either. The fuse is finne, any other ideas? Thanks!
97 TJ- REBB, Teraflex BL, MML, Some bling and mud kings
hoyttrucks is offline
post #2 of 7 Old 05-28-2006, 09:44 AM
woody-77
Vulcan FTW
woody-77's Avatar
2007 FSJ Cherokee
I had the same problem on my '97 TJ, had to replace the turn signal switch and stalk.
Gone but not forgotten: '86 CJ7, '06 Wrangler X, '03 Rubicon, '97 Wrangler, '77 CJ5, '74 CJ5(RIP)...gone and forgotten: 07 JK Sahara Unlimited, '78 CJ5
Thread deleted by Jerry Bransford
Reason: This was beyond human decency... posting about someone's girlfriend is ****ed up.
woody-77 is offline
post #3 of 7 Old 05-28-2006, 10:46 AM
M&C_TJ
M&C_TJ's Avatar
i have the same problem and here is what you do. you take the turnsignal out get a small finishing file and file the corrosin of the inside of the plug of the turnsignal. that is what i had to do and worked just fine when i cleaned it free of that corrosin crap
Rock Krawler 5.5 X-Factor L.A. Rock Krawler Heavy Duty Steering System AA SYE and TW CV DS
D44 w/ superior shafts/D44 w/ usa alloy shafts from northridge ARB front and rear
Pro Comp series 97 Rims holding 35" BFG A/T
M&C_TJ is offline
post #4 of 7 Old 05-28-2006, 06:39 PM Thread Starter
hoyttrucks
Actually I think it's an internal short or plug thats messed up. I am gonna take the stearing column off tomorow and check thanks, any other ideas
post #5 of 7 Old 05-29-2006, 02:24 AM
Sidewaize
Turn signals
Check the turn signal switch/ Hazard switch. This part commonly goes out and when it does, can cause all kinds of strange issues. The switch was causing my brake lights to malfunction, even though the third brake light worked fine.
Try activating your hazard lights and moving the hazard switch around. Might cause things to act funny. If it does, it'd definitely the switch.
Good luck.
Sidewaize is offline
post #6 of 7 Old 05-29-2006, 11:31 AM
c_gilbert
Make sure your hazard light switch is all the way in the off position.
1997 TJ SPORT - 4.0 - 2.5" Skyjacker Lift w/ hydros - Cragar BLACK Soft 8 - 31x10.50 - Warrior Rear Bumper - PIONEER 9600 Deck - FLOWMASTER 40 Series -
JKS 1.25" BL and 1" MML -
c_gilbert is offline
post #7 of 7 Old 05-29-2006, 01:20 PM Thread Starter
hoyttrucks
my hazard switch has never worked since I havee hadd the veep acually (3 months) and does your directional lever automatically shut it self off or do you have to do it manually on all jeeps because mine never has shut off by it self. Thanks
Clicking noise when I turn on the turn signals ScJeepaholic TJ Wrangler Technical Forum 10 04-08-2009 02:40 PM
Turn signals stop working when I turn my lights on? Toner12 YJ Wrangler Technical Forum 1 08-10-2008 05:54 PM
Turn Signals CFK2 TJ Wrangler Technical Forum 1 01-13-2008 08:01 AM
No turn signals bsruther TJ Wrangler Technical Forum 3 12-10-2006 02:19 PM
Turn Signals NCRenegade93 YJ Wrangler Technical Forum 3 02-24-2006 12:49 PM
