No spark - JeepForum.com
post #1 of 13 Old 03-04-2010, 09:32 PM Thread Starter
ewhitaker75
No spark
First off, I have a 99 TJ 6cyl. MT that had a dead battery, so I jumped it, ran fine, got back home and shut it off and went to drive again. It started fine and the engine shut off abruptly but still had battery. The engine would spin but not start.
Replaced (so far) plugs, ignition coil, cap and rotor and crankshaft position sensor.
What is left to check? Is it a PCM issue?
Thanks in advance
ewhitaker75 is offline
post #2 of 13 Old 03-04-2010, 09:40 PM
CRAWLING 98
Wheeler
CRAWLING 98's Avatar
Thanks in advance
Have you reset the computer? When you crank the engine do you get any spark at all?
Check all the engine fuses.
Group W Bench
CRAWLING 98 is offline
post #3 of 13 Old 03-04-2010, 09:41 PM
88blkyj
is it trying to fire after your letting off cranking?
do the tjs also have the ignition module on the driver side wheel well that is prone to getting wet?
88blkyj is offline
post #4 of 13 Old 03-05-2010, 06:51 AM Thread Starter
ewhitaker75
Checked all fuses under the hood. How do you reset the computer? Also swapped the ASD and A/C relays to see if that was bad but no difference
post #5 of 13 Old 03-05-2010, 07:47 PM
greekboy
Have you checked the camshaft sensor? Might be worth a try. Also check and see if you have any codes by doing the key sequence.
greekboy is offline
post #6 of 13 Old 03-05-2010, 08:36 PM
madmechanic
your tps could be done. they can get stuck in clear flood mode and this can cause a no start condition. but that disables injector pulse. are you sure you have no spark? the ignition module is part of the ecm.
madmechanic is offline
post #7 of 13 Old 03-12-2010, 02:33 PM Thread Starter
ewhitaker75
Took it to the shop finally, ended up having a short in the injector wiring that was on the same circuit as the crank position sensor therefore the sensor was bad allowing no spark.
post #8 of 13 Old 03-26-2010, 04:51 PM
Billyjoebob007
So if the crank sensor is bad there will be no spark coming from the coil ?
I'm trying to work on me roomies 97 , he said he hit a big water puddle and it died on him and now it will only crank and will not kick over. I tried shooting a bit of starting fluid in the air filter and nothing, i even tried pouring a bit of gas into the throttle body and nothing. I went to relieve the fuel pressure one the relief valve on the fuel rail and the gas did not spray out but only a little bit dripped out. I tested the ignition coil and there is not spark from the coil. Sooo, bad coil/crankcase sensor/fuel pump ???? We have let the vehicle sit and dry out for a couple days. Theres no moister inside the dist. cap and none in the air filter box.
Billyjoebob007 is offline
post #9 of 13 Old 03-26-2010, 04:55 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Correct, there will be no spark if there is no output from the crankshaft or camshaft position sensors. Have you tried reseating all the engine's electrical connectors, especially the ignition coil's 12v connector? Rinsing the connectors with WD-40 will get rid of any moisture inside, just shake the excess WD-40 out before reconnecting them.
Jerry Bransford is offline
post #10 of 13 Old 03-26-2010, 05:16 PM Thread Starter
ewhitaker75
Sounds like you have a bad fuel pump. Rent a fuel pressure gauge from autozone. Should be around 45-55 psi. Have someone lay under the fuel tank while you turn on the key and you should hear it energize. If it works, I'd check the wiring for a short as well. Good luck
post #11 of 13 Old 03-26-2010, 10:18 PM
Billyjoebob007
Yea i dunno though, I poured a bit of gas into the throttle body while some one was cranking it and it would not even try to kick over. I didn't i hear the pump prime when turning the key on , I will have to have someone turn the key while get back there and listen. I think it may be that crank sensor or the coil though.
post #12 of 13 Old 03-26-2010, 10:24 PM
Billyjoebob007
I tried a few, the connector for the crank sensor/the computer - took all three connectors off and 1 had some kind of fluid in it didnt look like water though, and i cleaned that up good, i did check the connector to the coil and it was secured, i will disconnect it and clean it though. To check trouble codes doing the key on/off trick how many times do you turn the key for that ? I turned it on/off three times then back on and the check engine light didn't do anything.
post #13 of 13 Old 03-27-2010, 05:51 PM
Billyjoebob007
Humm ok i found the problem, its the ignition switch and the i think its called the ignition start module, are both bad. who would've thunk it .
1999 tj , electrical , ignition , spark
No spark during crank but spark when key released...WTF? USMC_JeepGuy YJ Wrangler Technical Forum 16 08-03-2013 08:00 PM
spark from spark plug! AlaskaJeepMan TJ Wrangler Technical Forum 3 08-20-2010 06:08 AM
No spark on start, one spark on run. Benny88 YJ Wrangler Technical Forum 7 03-05-2010 02:38 PM
no spark gordonsjeep YJ Wrangler Technical Forum 1 01-14-2009 06:24 AM
88 yj 2.5 no spark help snofrog YJ Wrangler Technical Forum 1 01-08-2005 01:25 PM
