No shims installed with stock D30 pinion setup? - JeepForum.com
post #1 of 6 Old 02-05-2011, 12:26 PM Thread Starter
Lemmiwinks
In the process of re-gearing a D30. Removed the setup from my stock LP D30, removed the inner bearing race for the pinion. To my surprise, there were zero shims in the setup!! Anyone else heard of this?
Lemmiwinks is offline
post #2 of 6 Old 02-05-2011, 01:22 PM
JeSimmers
JeSimmers's Avatar
The shim(s) will be under the pinion bearing on a dana 30, and occasionally the oil slinger will be the only shim.
Red Jeep Club Member #454
JeSimmers is offline
post #3 of 6 Old 02-05-2011, 01:42 PM Thread Starter
Lemmiwinks
Checked.... there were none installed....
post #4 of 6 Old 02-05-2011, 03:40 PM
viperbluelx
so you pressed the bearing off the pinion and there was no shims or slinger there?
04 Rubicon, 5.5" RE LA with Tri-link, 35" KM2, 4.88's
viperbluelx is offline
post #5 of 6 Old 02-05-2011, 03:42 PM Thread Starter
Lemmiwinks
There was only an oil slinger
So it was the pinion / oil slinger / bearing
post #6 of 6 Old 02-05-2011, 03:43 PM
viperbluelx
that oil slinger is your shim, that's all mine had too, sometime you can get the right setup reusing it, sometimes you'll have to add shims, sometimes you'll have to get rid of the slinger all together if it's thicker than the shim depth you need
Pinion Shims, Part II cheapjeep06 TJ Wrangler Technical Forum 24 01-24-2011 08:08 PM
Pinion Shims!!! cheapjeep06 TJ Wrangler Technical Forum 4 01-19-2011 12:30 PM
shims broke and pinion angle? newtjrjrjr YJ Wrangler Technical Forum 2 12-24-2008 05:33 PM
Need pinion angle shims, help! Cobra Jeep YJ Wrangler Technical Forum 14 10-21-2006 02:25 PM
Stock TJ Foglight Setup: Where to find cheap parts or equivalent aftermarket setup hikerpaddler TJ Wrangler Technical Forum 3 08-06-2002 08:51 PM
