No rear track bar, does it matter? - JeepForum.com
post #1 of 10 Old 05-15-2006, 01:22 PM Thread Starter
TJ_with_Tusks
when reinstalling my rear track bar I broke off a bolt on the axle side. I ended up just leaving it off. It seems to drive fine and be stable. Do I have anything to worry about?
04' Columbia TJ
33" BFG AT's, OME HD lift, front airbag suspension, teralow 4:1 kit & supershort shaft kit, TW CV shaft, 4.10 gears, JKS body lift, track bars and quicker disconects, Warn 9.5ti, warn front bumper, garvin wilderness rack, and solid cast aluminum tusks,
TJ_with_Tusks is offline
post #2 of 10 Old 05-15-2006, 01:24 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yea, what is keeping your axle centered and preventing it from shifting side to side?
You need your rear track bar unless you have triangulated uppers.
Wheelin98TJ is offline
post #3 of 10 Old 05-15-2006, 01:24 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
You absolutely need the trackbar on any TJ that has not had its suspension triangulated. Not only will the rear axle shift out to the side in a substantial maneuver, especially in an emergency, the control arms can be damaged when that shift happens as they are not designed to withstand that kind of side loading.
Jerry Bransford is offline
post #4 of 10 Old 05-15-2006, 01:28 PM
wranglin
Not having a track bar is bad, very bad....
wranglin is offline
post #5 of 10 Old 05-15-2006, 01:30 PM
jeeptj19992001
Track Bars Are Over Rated, So Are Control Arms
03 rubi....growing bigger and better every day...
jeeptj19992001 is offline
post #6 of 10 Old 05-15-2006, 02:14 PM Thread Starter
TJ_with_Tusks
ok, glad I asked. I'll get on that.
04' Columbia TJ
post #7 of 10 Old 05-15-2006, 02:20 PM Thread Starter
TJ_with_Tusks
oh wait. I'm an idiot. Big typo .. Its the sway bar that I don't have. The track bar is fine. Do I need the rear sway bar ? ??
04' Columbia TJ
post #8 of 10 Old 05-15-2006, 02:24 PM
Jerry Bransford
Administrator
Yep, ya need that too to help balance the f/r suspension. Plus it'll handle far better with it attached & functional. I had three Boy Scouts with me on the way back from an offroading trip where I had unknowingly broken one of the two rear antiswaybar links which disables it entirely. We all noticed and they all loudly (but with good humor) complained about how the TJ was swaying & supposedly making them "seasick". I kept stopping to look to see what had happened but didn't find the broken antiswaybar link for a few more days. The lack of a rear antiswaybar definitely caused a very noticeable degradation in the TJ's handling.
post #9 of 10 Old 05-15-2006, 03:03 PM
jakeruner
i took my rear sway bar off and i really cant tell the diff,
jakeruner is offline
post #10 of 10 Old 05-15-2006, 03:23 PM
Achped
I've read that story now so many times. I feel like I could tell you the boys' names, what they ate that morning, and what they were wearing.
Just make it a sticky
Achped is offline
For the Explorer 8.8 rear axle does V6/V8 donor matter? YJ_Wrangler YJ Wrangler Technical Forum 2 05-20-2008 11:49 AM
Need some good pictures of a rear track bar or some kind of track bar mcgarys2007 YJ Wrangler Technical Forum 17 09-18-2007 12:59 PM
Rear stock coils... does it matter which end is up or are they the same on both ends. Beaverwrangler TJ Wrangler Technical Forum 6 05-23-2007 11:15 PM
Does it matter which way the rear main seal goes in? martells2 YJ Wrangler Technical Forum 7 01-08-2007 06:11 PM
Front Track Bar & Rear Track Bar Bracket mossimo19 TJ Wrangler Technical Forum 4 09-14-2005 07:56 PM
